Atari PSU US > UK
itruk
17 (100%)
451CR
I'm wanting to run my US import machine Atari cab using UK mains instead but I'm wanting to make sure I don't mess it up!
I've read about the voltage plugs, but I'm thinking I've read too much into it since it couldn't be as easy as just swapping them for the different voltage's?
I'm going off a UK Dig Dug machine, that I have, for guidance. So this has a Blue voltage selector plug (220V) and the mains is wired into the side like this..
and this is my US project, with a yellowish voltage selector plug (120V) ..
So for this to run on UK mains, would I just have to swap the yellow plug for the brown selector plug and then wire a mains cable to a molex and insert where the arrow above shows?
bbz149
26 (100%)
1,608CR
Cant find the info at the mo, but I just pulled that plug with the Turquoise wires (mine was Yellow) and changed mine to 240v there by cutting and joining the correct Pins. I think the correct UK plug just had Brown wires, cant 100% rem ATM. I got the info from the Webbbz1492020-03-29 21:13:03
aeroflott
A different league
16 (100%)
1,069CR
Correct - its usually the brown selector you need.
itruk
17 (100%)
451CR
Successfully did the swap and the machine now works on UK mains :D
But, the fluorescent is playing up. The actual starter is flashing and the ballast feels warm when I hover my hand over it.
Tried another starter, but with the same issue.
Is this because I swapped voltages at the mains?
itruk
17 (100%)
451CR
Small bump, finally getting around to the problem light fixture. I'm struggling to find a ballast 120VAC 50hz
So I might have to go the LED route. Where's best/safest to tap 12v from within the machine?
Or buy a 230V fitting, but that means it'll look ugly tapping into the wire before it connects to the PSU.
patloz
844CR
This is news to me as I have a few direct from the US cabs and all i have ever done is switch the plug wiring to 240.
I haven't touched the fluorescent tubes and they all worked fine ( and still do years later ) out of the box.
patloz2020-05-26 21:19:26
itruk
17 (100%)
451CR
Might be just an Atari thing then? It's certainly not a healthy sight. The tube flashes and the starter flicker's like a good'un.
The ballast also warms up a fair bit too.
Titchgamer
123CR
It should say the voltage rating on the ballast so if its only for 110v then you will obv need to change it.
If its rated up to 240v then it should of been fine.
The lamp may also have a associated voltage though (don't have much dealing with American light fittings lol)
All that aside if it was me I would swap it out for a low voltage LED batten, They run nice and cool so no added heat into the cab.
You could then just tap into the LV side of the PSU.
patloz
844CR
Al my cabs are Atari and I have never swapped any lighting and all have been fine just swapping over the 110 / 240 wiring block- and the fuse for good measure.
Plenty people on here know far more than me so I will check the cabs I have and see what the ballast says , I haven't ever checked but I assumed the 110 / 240 only related to the input voltage and the voltages in the cab remained" as is " whatever input voltage was supplied?
Need to look in one of the op manuals I have to see if the part numbers are different for the lighting between US and Irish cabs.
aeroflott
A different league
16 (100%)
1,069CR
I tapped 12V off the AR2 when I put an LED light in my Centipede cabaret.
More info here:
https://arcadeblogger.com/2014/12/01/atari-centipede-restoration-4/
Been fine for years.
DanP
Administrator
2,232CR
The problem isn't with the voltage it's the AC frequency. US leccy runs at 60hz, Europe and much of the world runs at 50hz. If you run a 60hz ballast on a 50hz supply it will run HOT and will eventually fail. At best you'll just have a much shorter life on the ballast, at worst - it will catch fire. It happened once at a UKVAC meet many moons ago (in an Atari Asteroids Deluxe). YMMV of course but I personally wouldn't run a US ballast. Finding suppliers for them running at 50hz isn't simple, there used to be a jukebox place in Germany that had them but they weren't cheap.
Dan
itruk
17 (100%)
451CR
More info here:
Ah, I thought I had seen it done like that somewhere! The J10 block on my AR2 isn't used, checked the voltages at pin 4 and it's not giving anything out
I've also seen someone tapping into a 10.3VDC point somewhere, just got to find out where that is on the PSU.
patloz
844CR
Thanks Dan, you learn a new thing every day, That said I don't run mine for hours at a time for days on end so my experience is very limited operation wise.
Will check mine and will may be easier and ultimately cheaper to fit new UK sourced light units next to the originals.
itruk
17 (100%)
451CR
Right going from my above unregulated 10.3V comment, this was tested on the PSU at about 15v (pins 1,2 or 3) GND at pins 4 or 5.
These wires lead to the AR2 at socket J6.
It has two chunky orange wires for the current and two purple's for GND. I'm guessing that this should be OK to 'hack' into?
DanP
Administrator
2,232CR
Almost every AR2 I've seen has a test point for the 10.3 unregulated supply. You can easily run a jumper from that.
