Atari PSU US > UK
itruk
17 (100%)
451CR
DanP said:
itruk said:
Ah, I thought I had seen it done like that somewhere! The J10 block on my AR2 isn't used, checked the voltages at pin 4 and it's not giving anything out
I've also seen someone tapping into a 10.3VDC point somewhere, just got to find out where that is on the PSU.
Almost every AR2 I've seen has a test point for the 10.3 unregulated supply. You can easily run a jumper from that.
Good idea! Just checked and the test point on the board reads 12.7V which is more like it. So I'm good to just put a spade connector on that, and a spade on the GND point next to it, then just run it to my lamp?
