Ordyne said:gunblade said:so after the initial chihiro splash screen it should load the game from the sd card and once its loaded the game will appear
i have never seen a chihiro not load the game and not error
do you think it should be automatically loaded into the ram, it would if your rechargeable battery was all good otherwise it has to load the game from card each time
Sounds to me like he's jumpin into test mode before its started loading. hence why if he waits long enough the game title will show up as it will keep loading in the background.
I’ll need to look at the battery and see if changing it helps. I have a spare chihiro that has other issues but hopefully the rechargeable battery works in it.
I was waiting around 4-5 minutes to see if the game would boot before going into the test menu. I had expected around 2 minutes would have been about right for the game to boot normally.
