Chihiro Help
jasonm737
270CR
Ordyne said:
gunblade said:
so after the initial chihiro splash screen it should load the game from the sd card and once its loaded the game will appear
i have never seen a chihiro not load the game and not error
do you think it should be automatically loaded into the ram, it would if your rechargeable battery was all good otherwise it has to load the game from card each time
Sounds to me like he's jumpin into test mode before its started loading. hence why if he waits long enough the game title will show up as it will keep loading in the background.
I’ll need to look at the battery and see if changing it helps. I have a spare chihiro that has other issues but hopefully the rechargeable battery works in it.
I was waiting around 4-5 minutes to see if the game would boot before going into the test menu. I had expected around 2 minutes would have been about right for the game to boot normally.
gunblade
9,144CR
i don't understand what you are doing
you just turn the machine and and watch it, if it going to load a game it will say loading game and then you just leave it
don't expect things from arcade stuff, its not a home computer - they do what they do
its the dimm battery that you should check and if it is good then it needs to left on for at least 6 hours to charge
Vamino
Insert coin(s)
2,700CR
Gary/Outrun2 made this movie a while back showing GDROM Vs SSD boot process. GDROM takes about the same time as CF, so you are looking over 5 mins for it to load. For CF, 2 mins is being very optimistic.
Outrun2
Colonel Outrun
1,184CR
Wow one of my old videos! Not my most exciting of videos, but it has come in useful a few times over the years
I'd like to see what setup is in the Chihiro as I've never seen a loading sequence go up beyond 100% to 200%, 300% etc.
Loading from SSD shows the on-screen progress counter go up to 100% as the original GD-ROM solution did, but netbooting doesn't show anything on-screen except 'Loading game program 0%' so you have to wait for the Pi or whatever to say 'Transfer Complete'. It does then enter the game though.
I'm guessing this is some kind of Chinese hack..??
Fantazia2
2,246CR
From your original photo it looks like the monitor is adjusted too big vertically as the test menu shows the bottom text being cut off, it could be when you are turning it on the loading text is being cut off the bottom of the screen.
chris2922
333CR
So maybe there is nothing wrong with it at all and you are just not giving it enough time to load.
If you turn it on and leave it a full 10 minutes without getting impatient and pressing buttons, what happens?
jasonm737
270CR
Yeah the screen thing was a good shout. I am cutting off the bottom of the screen so i’m not seeing the loading info properly. After reading the comments and watching the YouTube clip of how long it takes to load, i turned mine on and left it. It took over 10 mins to boot, but as you’ve all already pretty much called out, it booted and i was clearly being too impatient. I’ll go hang my head in shame and stick the dunces cap on. Need to get in the back now and sort the crt so i can see the loading info in future.
Thanks everyone for your help and patience.
