CPS2 Battery replacement
5,653CR
What game is it? There are some decryption kits available now that aren't the Razoola versions.
If not the battery is usually about £7 from Farnell/CPC etc. I don't have a part number currently sorry.
ben76
Hunts Spies
1,136CR
Some info on Porchy's site
http://www.jammarcade.net/cps2-suicide-battery-replacement/
HTH
-Ben
obcd
3,830CR
The tutorial is good, but usually, I cut the wires off the old battery and solder the new battery wires to the wire ends of the old batteries still sticking out. After that, the battery is fixed with a drip of hot glue. The reason I work like that is because it can be pain to remove the solder from the holes where the battery wires go in. Specially the battery minus lead can be connected to one of the inner ground layers of the pcb. Maybe it's not the case here.
