Cutting plexi marquee
strykr
1,351CR
I need to trim down an original marquee its about 4 mm thick acrylic/plastic/plexi. Has anyone ever done this? If so whats the best method? Art is screen printed so dont want to damage it.
strykr2015-12-18 00:27:57
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Just a thought but how about marking the size you want then with a sharp blade mark where you need to cut. This should then hopefully stop the print from cracking then use a new blade in a hacksaw.
Try out first on a old marquee if you have one.
Hope that helps
aeroflott
A different league
16 (100%)
1,060CR
I score as deep as I can with a craft knife using a metal ruler then snap over the edge of a table. Nice clean cut that way.
But don't blame me if you mess up your nice marquee. ;)
strykr
1,351CR
its pretty thick to get through with a craft knife I think. But might try that, Tony i'll invoice you when i shag it up
Im not sure I can get a nice clean line with a hacksaw but these are definitely options to explore! my concerns are cracking/melting it, if i get power tools involved. Has anyone tried these methods?
strykr2015-12-18 10:06:52
2,265CR
Tony's method is what I was going to suggest also. Far less likely to get cracking, just make sure it's properly supported from underneath. I've tried doing one with a saw and it cracked in 2 places when the blade got stuck a little - although that could be down to me/or the blade!
Hurray Banana
2,755CR
I've cut with a router, but you really need a router table so you can keep the bit at 90 degrees to the piece, still potential to crack and melt, need to test with a scrap piece of acryllic of the same thickness (but you probably haven't got that) to see how easy this is.
You can wedge the marquee between a couple of pieces of scrap mdf to try and help stop any vibrations to help with the cracking issue.
At the end of the day it's probably a sh*t or bust job cutting this by whatever method.
Hurray Banana
2,755CR
Very fine tooth blade is best for this sort of job, like a hacksaw blade as steve suggested, less likely to catch
Mr20to5
1,366CR
My ten pence amateur suggestion, which works for me, but I've never tried the 'snap method' so can't comment on that.
For me, I use a very fine toothed handsaw to cut close to the marked line then I run it through my router table on SLOW speed to finish the edge to the line. It works for me. You can't take much material off this way as the cutter, set on slow speed, will pull the material and make a right mess, and if you increase the speed, it will melt the edge.
Cracking is the enemy, so take your time whatever you choose.
big10p
Coins detected in pocket!
6,085CR
That pretty much sums it up for me. It's just nasty material to work with. As I don't have a router table, personally I'd just go with the craft knife option. It takes more time and effort but worth it in the long run, IMO. Change blades a few times, too. A knife with snap off blades is a boon. Power tools and hand saws love destroying perspex/acrylic, in my experience.
big10p2015-12-18 11:10:24
strykr
1,351CR
thanks for your suggestions fellers, seems its a bit of a gamble no matter what method! I have no router table etc, so I'm down to knife or hacksaw, I think it may just be a case of clamping and a LOT of scoring with a knife!
big10p
6,085CR
vib_ribbon said:
would it be easier if you softened it up a bit in the oven first?
That's an idea I haven't tried. I use a paint stripper heat gun for bending plain perspex - works a treat. Wouldn't go near a painted marquee with it, though!
If scoring with a knife, I'd cut from both sides. It would probably snap apart pretty cleanly, once you've cut most of the way through.
Hurray Banana
2,755CR
I think you should do a video when you do finally attempt this Rich so we can see how fraught or not a process this turned out to be
Wurstkopp
126CR
Doing this for years with japanese saws:
http://www.shokunin.de/WebRoot/Store11/Shops/62075595/49AF/B96C/A314/1705/4276/C0A8/28BD/E9B2/Japans_00E4_ge-Kataba_0020_250-Bakuma.jpg
DABYX
109CR
Another spanner in the works, when cutting some plastics with power tools documents I've read say to reverse the teeth if using a eg. Circular saw.
Stops binding and also pace it and perhaps lubricate with water etc to avoid melting from heat.
But yea, personally I'd try a sharp knife to begin with at least as others suggest.
vib_ribbon
488CR
one of the marquees i bought from the states had a big bulge in it due to the heat of a light bulb i suppose, and i put that on a sheet of wood and put it in the oven (with the door open) and that partially remedied the problem. if my oven was bigger i think it would be better. but for you to suggest a heat gun instead, i think that's a pretty good idea to maintain the heat, but then you'd need an extra pair of hands.
i've used the heat gun to bend sheet plastic as well.
strykr
1,351CR
. Can be part of my new series "Arcade fails 101"
