I've got about 12 motherboards and various other bits, I also should have one (or more) carts without the security chip (i.e. it is wired to bypass it) so you can put whatever game you like on there, so I *should* have a complete set of PAL's
if you need any I can dig out the PAL cracker (or see if they read!) and try and dump them.
Porchy can then add them to his page
if you need anything in the way of boards I can check as I probably have spares
(it would be fairly easy to knock up your own carts since they are just 3 banks of roms - code, speech and graphics (if you bypass the security chip and use one bigger rom for each bank), but the board has to be the same size to have the connectors in the right place!
