Damaged chip?
Mark
3CR
Hi all, I’m very new to to arcade pcb’s and would like to just post a picture of a board I’ve just received. I can see some damage/old repair (not sure). I’ve not tested to see if it works yet and could be a week before I get the chance. Would you guys be able to take a look and give me your opinion on why or how the chip connectors look the way they do and maybe and maybe give me some advice if I find my board doesn’t work. Thanks a lot.
5,332CR
Very ropey.
I’ve not seen enough boards to be sure how it got like that.
If it was bashed on the pins, it would be more localised than that.
If it was a bad resolder job, I’d have expected all sides of the chip to look like that.
If it was severe rot, I’d expect more green/blue bits and that wouldn’t explain the flux-like gunk on it.
Maybe a mixture of the above. John Bennett2019-09-05 18:14:03
bones
1,628CR
Yeah looks ropey but everything looks connected, the Taito square chips always come away from the PCB,got a couple of the football ones with that problem.
I think the previous owner may well have done the repair with a standard soldering iron by the looks of it,tricky at best.
Hope it turns out to be working for you,if it does try not to stress the PCB in any way or stack anything on top.
5,332CR
I can see how it’s still possible, but I think you’d be lucky for all of those pins to be in contact.
Could all be sorted, but how’s the rest of the board?
Ace`
PlanB contributor #1
40 (100%)
4,043CR
Looks like old flux or maybe nicotine, nothing to worry about. There's a few bent pins but I can't see any that are shorted.
Mark
3CR
Thanks for your response guys. I’ll hope for the best. Should I try to clean it up? If so can you suggest how I should do that.
Mark
3CR
I only had a few mins to look at the board. Didn’t see anything else as bad as that. I’ll be having another look when I get home from work.
5,332CR
I’d be inclined to leave it until you can run it.
If it doesn’t work, have a fight with the seller if it was sold as a working board and it isn’t.
Better that than dislodging pins or pads before you’ve tried it.
Mark
3CR
I’ve just looked closer at my own picture. Is this a capacitor missing? In the side with all the damage? Where c33 is written.
940CR
I had a Super Space Invaders 91 pcb once, and that exact custom chip had bent or damaged pins, the sound stopped working, then I tried to fiddle with the legs and the board totally stopped working. I would certainly try it before touching anything on it. Oddly it was the same top corner on my old one that was damaged, mine did not have all that yellow stuff on it though.
Mark
3CR
So annoyed:( can’t even test the board as the cga-vga converter that got delivered at the same time.( one month wait) doesn’t work. Title screen comes on for 1 second and then “no signal”.
