Daytona problem
FinalFight
73 (97%)
770CR
The pcbs are actually really clean as i aways check soon as i get cab,I dont understand how its just gone from being moved from here to rich.
https://youtu.be/avyvhGNJNeU thats the video i made after the right side had a replacement chassis from gunblade.. it was then seperated ready for pickup stegrey2017-09-18 20:24:33
Rockstar
2CR
I was hoping it was just a plug to start but I have cleaned and blown out all of the ones that where disconnected. And checked a lot of them inside aswell. Will check the main box tomorrow. Thanks for all the advice guys it's appreciated hopefully will be something simple typical it's my first cab ??
3,584CR
If it still does it after reseating/cleaning stuff then put it in service mode and find the board test menu. Once it's gone through its tests it should with any luck bring up which chip (almost certainly video ram) is causing the fault. It'll be a surface mount chip but they are replaceable.
seanr28
9 (100%)
319CR
There is, but video boards for the model 3 step are not cheap......try what we have suggested first, if that dont work then you have 2 choices, either purchase another video board or have that one repaired.
FinalFight
73 (97%)
770CR
its definately something thats gone wrong in the stack then.. i would try reseatting the boards.. rich can you send me a video of the noise.. sounds like its been bashed about :(
6,093CR
You sure the 'crack' sound is coming from the monitors? Sometimes when you fire up a cab, you can get a quick burst of sound through the speakers, as the amp powers on.
Outrun2
Colonel Outrun
1,184CR
This ^^
Normal on Model 3 drivers with the sub and gullbox speakers.
Or if it's a Japanese built cab they have a contactor that makes a loud crack when powering on.
FinalFight
73 (97%)
770CR
speaking to rich i think he means the startup noise of monitors like the click whats normal or the speakers, i wanted to go past to have a look at the pcb with him but hes up in london im in liverpool :( only thing i can think to do reseat the board stack if its still the same do the board test if its still not working we will need to get it looked atstegrey2017-09-19 11:55:48
