*FIXED* MVS MV1 Jailbars on some sprites
Brettster
20 (100%)
1,232CR
I got 3 dead MVS boards from Frothmeister
the best of the 3 started up with just a static green screen, I've since learned that this a calendar issue, usually caused by a leaking battery, Sure enough all 3 boards have had battery leaks.
Anyway I was able to get this to boot up using a universe bios, but It had no sound and a problem with the Graphics as seen below
Neo Geo boot up screen works fine, and most none animated graphics are ok
I was able to get sound working too by swapping the cartridge connector with one of the other faulty PCB's
coin up and controls work fine so this one is very close to being 100% working. just the lines to sort, am I right in thinking this is usually a RAM issue? if so how do I check which one it is?
I've been able to confirm connectivity with all the pins in the upper section near where he battery was and all the traces that look bad are still showing a good connection
Randomly probing with a logic probe did not bring this pcb back to life though
Brettster2018-03-10 16:16:14
Flinnster
The Dino King
29 (100%)
2,566CR
Ah I will be awaiting answers and trying to learn on this one too. I have a non-booting MV1FS here and an MV1FZ with that same calendar error. I suspect similar .. that some chips have gone bad somewhere.
robotech
823CR
I have fixed a few of these recently with the calendar error (stuck on green boot screen )
Clean up all of the battery acid leakage
And repair any traces running to the
The calendar chip it is the one near the 32 mhz crystal
Also change the crystal and fit a coincell holder with rechargeable 2032
There is a test bios i have seen people using to test backup ram on socketed bios
Mvs boards robotech2018-03-06 03:35:51
t-m
333CR
This is the MVS clock circuit. You can check the crystal with a 'scope if you've got one also the outputs of the clock chip. I also had a dead 74HC32 produce the calendar error.
Brettster
20 (100%)
1,232CR
everything in that area has had a dose of battery fluid by the looks of it
the Universe Bios ignores the issue and lets it boot anyway but will the Clock circuit work without a battery or is it needed to function?
I've removed the Batteries from all 3 boards that I have at the moment
Brettster
20 (100%)
1,232CR
Happy to say this is now FIXED
after burning the Neo Diagnostics Bios everything came back as working!
so next I checked all the pins had connectivity from the main board to the cartridge slot, theres about 300000000 of them!!
they all checked out too
then I got the microscope out and carefully checked the whole board for broken traces and found one!
patched it with a jumper wire and BINGO!!
Another Neo Geo Saved
just 2 more to go now but they are not even booting up
one boots to a black screen
the other doesnt even get that far!
Brettster2018-03-10 16:19:46
pulstar
40 (100%)
444CR
Cool. Nice fix there. With the non-booters first step would be to check the CPU is acting correctly, check the reset pin. address and data buses etc.
t-m
333CR
Nice fixing! I've got a 4-slot with track rot and it's driving me mad.
If you find the CPU resetting check the state of the bios chip socket... I had a couple recently pretty ropey, one needed replacement.
