Thanks. The multi board is a Pandora 4S and works without issue in another cab. Its the same board which was in when I tried the coin mech. When it flipped it and starting coming out of the game I used another board (Arcade classics) which worked (I did not try the coin mech again) but since then this board seems fried as a red light is shining on D1 (Also, it has been a few weeks since the initial coin mech incident). I think its unrelated but just mentioned it incase its worthy.
Edit: I haven't checked voltages or anything like that as I don't have kit/knowledge. What I've done is switched it off and back on. Then off again and back on, several times, each with diminishing hope. Took out which I believe is the coin mech wire and tried again. Tried the IO test. Disconnected player 1 A button and reattached, tried again. And looked for posts with similar problems but found no joy.
Moggle2018-09-04 22:00:09
