Game Start issues
Moggle
4CR
Before testing the coin mechanism, the games played without issue. Since putting in a coin in the coin mech when selecting a game on a multi board it starts then goes straight back to main scree. Any ideas?
Thanks.
Moggle
4CR
Will get pictures. I have disconnected coin mech wire and still doing it. When I try to do an IO test, player 1 button A sends you back to main settings screen when its hit. I wonder if this button is the fault and acting as a trip/reset?
7,230CR
Its possible but I doubt it. Have you checked voltages going to the board ?? If it worked before you connected the mech then the mech may have damaged the board (Put to much voltage through) some coin mechs can do this if they are not set right. Some require a Zener diode to stop the mech from damaging board. Hard without seeing it in person.
P.S grab me some pics see what we can work out.
7,230CR
Just checked Mech (Sorry didn't see you had posted the model) its a 12v mech so depending on the game board (most probably 5v) it is possible you have sent a 12 volt signal to the board. Not 100% though just a theory.
Dave
Moggle
4CR
Thanks. The multi board is a Pandora 4S and works without issue in another cab. Its the same board which was in when I tried the coin mech. When it flipped it and starting coming out of the game I used another board (Arcade classics) which worked (I did not try the coin mech again) but since then this board seems fried as a red light is shining on D1 (Also, it has been a few weeks since the initial coin mech incident). I think its unrelated but just mentioned it incase its worthy.
Edit: I haven't checked voltages or anything like that as I don't have kit/knowledge. What I've done is switched it off and back on. Then off again and back on, several times, each with diminishing hope. Took out which I believe is the coin mech wire and tried again. Tried the IO test. Disconnected player 1 A button and reattached, tried again. And looked for posts with similar problems but found no joy.
Moggle2018-09-04 22:00:09
Moggle
4CR
7,230CR
Ah got you ( I think ). If the 4s works ok in another cab then its going to be your power supply or wiring then. Just to confirm :-
4s and other board work fine in another cab ???
Where are you located ?? The only way is for someone to take a look at it really if your not confident in having a go yourself (Nothing wrong with that , Sensible if you ask me ! ). last thing you want is to make it worse.
Moggle
4CR
Yes the 4S works fine in another cab. It worked fine until putting a coin in the coin mech and since then it hasn't. Im located in Newcastle. I do know a sparky, I will ask him to take a look. Thank you again for your help. I will report my findings.
7,230CR
Ok mate, Sounds like power supply has gone then. Ask him to check the voltage at the PSU and also at the board (5v, -5v & 12v). Here if you need any further help, Shame you are so far away I would have no issues coming and taking a look.
qjuk
51 (98%)
2,139CR
Have you tried disconnecting the blue rectangular coin credit board? I’m thinking maybe something is not wired correctly on that. I’m sure on some of these older credit boards you can also set the coin credit pulse to a positive voltage (rather than the usual ground). Maybe that’s causing the problem? What game board was the coin mech and credit board connected to before you put in the 4S?
