Got an Operation Wolf cab and just starting the exciting repair journey.
Initially plugged it in and no signs of life. Checked the cable and saw it was two cables junctioned together (badly). Temporarily (yeah right) soldered the cables together and liberally applied electrical tape (junctions are in the bin).
Drilled the lock and took a look inside. Not too shabby; no hacks, the board looked ok and everything seemed attached.
Flicked the switch and either the monitor chassis or the neck card sparked. Switched it off and thought I should probably pull everything out and check voltages and fuses etc.
Before I get it on the bench I'll give the whole board a clean. Not sure why but whilst I was cleaning I opened the psu. Nothing obvious has blown and caps are ok. That was it for the night.
Tonight will be more cleaning and hopefully some multimeter fun. I'm not great when it comes to monitor chassis so I'll just discharge, inspect it and them probably post it to Gunblade (along with my T2 monitor chassis).Nes4life2016-09-01 09:24:35
