Getting OpWolf running
Nes4life
1,134CR
Got an Operation Wolf cab and just starting the exciting repair journey.
Initially plugged it in and no signs of life. Checked the cable and saw it was two cables junctioned together (badly). Temporarily (yeah right) soldered the cables together and liberally applied electrical tape (junctions are in the bin).
Drilled the lock and took a look inside. Not too shabby; no hacks, the board looked ok and everything seemed attached.
Flicked the switch and either the monitor chassis or the neck card sparked. Switched it off and thought I should probably pull everything out and check voltages and fuses etc.
Before I get it on the bench I'll give the whole board a clean. Not sure why but whilst I was cleaning I opened the psu. Nothing obvious has blown and caps are ok. That was it for the night.
Tonight will be more cleaning and hopefully some multimeter fun. I'm not great when it comes to monitor chassis so I'll just discharge, inspect it and them probably post it to Gunblade (along with my T2 monitor chassis).Nes4life2016-09-01 09:24:35
maskeddev
88CR
Wishing you all the best with this one mate
Nes4life
1,134CR
Looking at other european OpWolf cabs on Google I'd say it wasn't particularly faded in comparison.
I guess it'd need a new set of artwork if someone felt strongly enough but it actually looks pretty good in person.
And yes, it's a beast. A beautiful beast.Nes4life2016-09-01 23:32:39
Nes4life
1,134CR
Cleaned and now on the workbench for further checks tomorrow. Opened the thing with the two fuses and found the main cap had a lifted contact. Soldered it to a nearby component on the same track using a single piece of mains wire and checked continuity.
Nes4life2016-09-01 23:40:02
dj_yt
787CR
I'd love to play an Op Wolf cab again. Can't have played one since the late 80s now.
Look forward to reading the restoration!
kiels20
125CR
I wish you all the best with this one buddy. Half way through my restoration and dear lord what a brain melter. Ill keep my eye on this post and ill help when I can
Nes4life
1,134CR
Voltages all read ok. Filter receives 240V and kicks out 240V, transformer receives 240V and kicks out 10V, 11V, 110V, 100V, 128V and 120V AC. Switching PSU receives 100V AC (I know right?!) and is kicking out 5V, -5v, 12v DC and the 'Connector Box' is receiving 10V & 11V AC and is kicking out 13V DC and -12V DC.
I checked the connectors to the monitor, PCB and sound board and all is well. I suppose I should build an OpWolf to Jamma harness (just video-out) so I can see if the board is working.
More detailed photos to follow tomorrow.
BarrySlisk
162CR
"I guess it'd need a new set of artwork if someone felt strongly enough but it actually looks pretty good in person."
I have never seen repro-artwork for the European cab. Sure it exists?
paulcan69
946CR
That's crazy there's nothing wrong with that side art
It's just the photo isn't great and it's not showing its colour depth
That's real original screen printed goodness don't cover it up with a sticker
They all look like that (it's not faded)
They just use a few greens making it look a bit dull
RGP
Meeter & Greeter
2,039CR
With ref to your monitor arcing, discharge the tube, remove the anode cap and clean just around the receptacle and where the cup would go with some IPA 90% or better and clean the cup and HV cable all the way to the flyback.
Put the anode cap back on and secured properly, park yourself behind but away from the cab and power up.
Do observe where the arcing is happening if it still occurs but i've seen this arcing problem a fair few times with cabs that have been stored, moisture and other crud gets under the anode cap and allows the HV to leak out.
It could well be the flyback arcing - especially if its a POLO chassis in there as they tend to split just around the HV cable entry point and then the HV jumps to the metal frame.
Either way, clean it up first and see what happens.
scubawaz
37CR
Nice cab don't change the artwork we've got the same one just got ours fully working with a massive thank you to IRONGIANT if you have trouble with the pcb he's the guy to sent it to. We've had countless things wrong with ours that we've managed to fix so keep posting these updates and I will keep checking to see if there's anything I can help you with.
Nes4life
1,134CR
Thanks all. I'll keep plugging away at this as and when I can. I've got a number of projects on the go.
I've never considered replacing / covering the side-art as it looks great!
Nes4life
1,134CR
OK, main PCB, IC 21 (74LS393) counts up and pin 6 eventually hits its high state which causes the reset.
IC 20 (MB3771) pin 8 is always high (not causing the reset).
It's my guess that the program EEPROMs are not read by the CPU and so the count on IC 21 is never cancelled and so it resets the board (as the watch-dog). Sound right? I haven't validated / re-burnt the EEPROMs yet.
