Gorf Arrival - issue
bud2
24CR
Howdy,
I picked up my Gorf today :)
It plays fine, everything is working, however the issue is the image.
It is very grainy and dim.
I am not sure if its anything to do with the monitor or the boardset( perhaps the video generators or whatever they are called).
So I need to rule one or the other out.
I shall mess with brigthness on the flyback tomorrow to see if that helps etc. I am not really familiar with the Gorf monitor layout, looks alien to me.
Does anybody have a working Gorf I could drop my boards in to perhaps?
Any tips would be most helpful.
I suppose a video would be more helpful also?
bud22016-09-21 18:24:52
Hurray Banana
2,766CR
Gorf is a little grainy because ut outputs composite wgich us converted to rgb so its nit pin sharp lije pure rgb games.
Like Ian says give everything a wipe down first then check all connector pins for signs of corrosion and replace with bew crimp pibs. Rgp (james) sells suitable pib replacements if you don't have any lying around. Check the link in his signature
Edited because of awful phone typingHurray Banana2016-09-21 18:55:11
bud2
24CR
The tube, bezel and smoked overlay are spotless, so not a dirty clarity issue.
All tests come back fine in test mode also.
Will check over thoroughly tomorrow, been a long day and drive but worth it.
Shiny, thanks, I know you are working on yours so any readings etc give me a shout happy to help.
Edited to add: didnt know that about the grainy stuff, thanks HB
edited: removed irrelevant info
bud22016-09-22 11:07:22
bud2
24CR
Well seems all the connectors board wise etc are in really nice shape, there is no corrosion or any evidence of it :)
I have turned up the brightness on the monitor and adjusted the monitor but its still real messy.
I left the brightness turned up and made 2 quick videos to show what i mean.
The bars are just scan lines the camera picks up.
The writing is very shimmery and real grainy.
http:////youtu.be/u-LNvA8CuVw
http:////youtu.be/1dQuGzh6Ik0
cheers
Jase
294CR
My money goes on it being the RGB board. Those things need either replicating albeit using a better technology, or a hack to make the use of it redundant. Stupid thing!
Congrats on joining the Gorfian Empire anyway, it's a great cab and a great game! The second cab I ever bought 20 years ago for a princely £25!
bud2
24CR
Ok, so I have done reading and think I could bypass the rgb board to confirm if it is faulty or not:
Find the video output on the video pcb and feed it into the composite inputs on a tv/device"
So just grab some RCA connectors and go for it?
Anyone in agreement?
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Also looks like it ok'd be a rgb board fault. Gorf is one of the coolest games around so stick with it. Remember to check if the custom chip at u15 has a heat sink.
I fitted a fan on top of my pcb cage to draw heat away from the cage just to try and help preserve the life of the pcb
Fuzzy
19 (100%)
585CR
Every GORF I've ever seen has an image like this, even BITD.
Same with Astro Blaster.
Nice acquisition, BTW,
bud2
24CR
Hi,
I did consider putting a fan in as Steve suggested
so will definatley do this.
There is a heat sink but I read it would be prudent
to put another on the other chip ?
Where the heck do I get one ?
Suppose a regular heat sink would be good but open
to suggestions.
RGP
Meeter & Greeter
2,039CR
Hey Guys
I've not seen that particular kind of problem with GORF per se, I have two possibilities here:
1) Bad grounding on the monitor neck to the tube or other similar monitor issue.
2) RGB board is picking up interference.
3) Could be your pattern board - this can sometimes generate snow BUT usually it is within the virtual border of the game playfield on the screen.
GORF is an awesome game and well worth preserving. Its a game that plays absolutely terrible in MAME and 15 years on they've never fixed the emulation issues that are noted.
One day i'll make an FPGA (like JROK) version of the astrocade system and we'll all be able to play GORF forever.....
Anyway, how to resolve your problems.
1) Switch off, wrap up neatly and ship to me for safe keeping ....
just kidding!
I believe you can indeed take the outputs from the loom and hook them up to component video inputs on something like a VCR or other SCART device via a suitable converter - don't get into the complexities of making a scart cable up.
GORF uses YPbPr (Yipper) output or in Midway speak R-Y, B-Y, Y+SYNC.
R-Y pin = Pr
B-Y pin = Pb
Y pin = Y
If you're interested at all in the video encoding then wikipedia has a good article here
Remember to ground all three cables if using phono's.
This would eliminate the RGB board or confirm its the source of the problem.
If you don't have time for any of this, you can send me your PCB stack and RGB converter and I can put them on my test loom.
I can fit you a heat sink at the same time, I don't list these on my store yet because I haven't found a good constant supplier for them plus you need a decent tube of thermal bonding compound as well and I can only ever find large tubes - that artic grey stuff for PC's is no good for these type of chips.
Please don't run your game for too long without a heat sink on the data custom chip (the one in the middle of the CPU board - U15 sounds right, I haven't got a set near me).
The address chip (U3) almost never goes bad, its the data chip - for whatever idiotic design reason they chose to put two voltage regulators in it - a 2.5vDC and a 7.5vDC - the input voltage to the chip is 5v so a lot of heat is made the chip which unless dissipated properly will just kill it. Probably the same kind of design thinking that says lets use composite video instead of RGB like everyone else does.
Nobody's cracked this custom chip yet, I keep pestering one or two known chip-crackers to work with me on this - up until recently, ATARI's Slapstick chip was also a huge problem so we shall see on this one.
bud2
24CR
Hi Guys,
I missed these new posts so apologies.
As of yet I havnt had chance to do anything - sorry- I have been to mixed up with my SWC Resto.
I may well take you up on the test rig RGP if thats ok ?
I shall do the things mentioned in the next couple of weeks or maybe sooner if my mind overcomes my will power to stay focused on one project at a time :)
