GUIDE: Sega Mega Tech 6 Button Mod
purple
-1 (0%)
1CR
Sega Mega-Tech 6 Button Mod
Hi everyone, since i’m new member of the forum i would like
to share one of my Project that keeps me
busy since december 2013, i think the title and the explains everything but
here is my story. I’ve met some very talented guy over spanish forums nickname
Giacomo Agostin, he is as intersted as me about sega mega tech but also is more
talented than me on electronics. J.
He is the one who figured out this beautiful mod. I dont have any knowledge
about designing circuits using kicad or similar software and i dont know
anything about how 74hc/ls buffers are working, i still havent completed mod but i decided to
share it here maybe actual design can
change in the future. I’m going to send it fabrication soon and it can be
useful for others. Giacomo, thanks for guiding me about it and sharing your designs
with us.
The six button mod is a little bit hard to explain it.
Basically you need to take off 5 IC from the Mega-Tech board and solder sockets
instead of them. Then you must plug a pair of PCBs over those sockets. The
signals that Mega-Tech uses to receive the buttons goes through the ICs and we
need to mix them from the ones coming from the Megadrive pads using AND gates
and a few buffers to prevent any damage to the board.
Here you have the PCB of the final boards (and another
one that I designed for another project). As you saw on the pictures I posted
on the forum, the 6 button mod is made on prototype board and it´s a little
different from the PCB on KiCad (I didn´t tested this one yet but I suppose It
will work perfectly).
If you want to make this mod, be very carefully taking
off the ICs and replacing them with sockets. I had some troubles to clean the
pads to insert sockets.
The ICs from Mega-Tech board that you have to take of
are all in line. An 74LS257, 74LS244, 74LS08 from the left side and 74LS257 and
74LS32 from the right side. Between them is an 74LS32 that you have to leave on
its place.
As you can see on these pictures, I used some
pin arrays and more sockets to raise the board. The buffers used in this board
are 74LS125, but the final board will use 74LS244 buffers.
Final Board
purple
-1 (0%)
1CR
Not quite sure if that works with IC's already there. It would be
much easier if you cut the legs first with mini cutter, then
you can remove the remainings by heating them and pull them softly with
the pilers (you can use mini cutter again to pull them but be careful
to not cut them) and solder the socket. This is really easy but you will
lose your original IC's so you need the order replacements. Seems like
new HC versions are working, fine.
You
need four 74LS08, three 74LS244, two 74LS257 and one 74LS32, I'm note
so sure about the sockets maybe we should discover better mounting
option.
74LS08
http://www.ebay.co.uk/itm/10-New-Quadruple-74LS08-2-Input-Positive-AND-Gate-DIP-14-IC-Better-Quality-K75-/171325199697?pt=UK_BOI_Electrical_Components_Supplies_ET&hash=item27e3c71551
74LS244
http://www.ebay.co.uk/itm/5x-LS244-SN74LS244-Leitungstreiber-8-Bit-Bus-DIP20-/310883274504?pt=Bauteile&hash=item4862164f08
74LS257
http://www.ebay.co.uk/itm/2-x-74LS257-4-Multiplexeurs-2-1-3st-CL257-/180631363773?pt=FR_YO_MaisonJardin_Bricolage_ElectroniqueComposants&hash=item2a0e77e0bd
74LS32
http://www.ebay.co.uk/itm/3pcs-74LS32-7432-SN74LS32N-IC-Quad-2-Input-Positive-OR-Gate-DIP-14-/281085590531?pt=LH_DefaultDomain_3&hash=item417201bc03
Some cheap ones I can find, And here is another picture shows final design in place.
purple
-1 (0%)
1CR
Ok people, it seems like the cost of all parts for building each one of
these are around £25, considering building time and effort I will give
to them, the final price I'm thinking will be around £42. Minimum order
of parts that I need to purchase are enough for building 6 of them.
Thats much money for me to invest right now, so it seems like the best
way to make it happen is collecting money beforehand.
If anyone
need this ,I need minimum three people to make payment so I can start
ordering parts. I hope everyone understands that it is kinda risky move
for me to invest all that money and wait people to buy it since there is
no such a demand for something like this.
I will list every
progress of building under this topic. Please pm me for my paypal for
preorder this. Thanks for eveyone interested.
glstar
160CR
very good project.
just to understand....
but this mod allow you to play megatech with a 6 buttons genesis controller?
no way you can use this mod on the original cab too?
purple
-1 (0%)
1CR
Yes both 3 and 6 buttons controllers work we will also try some sms games and sms lightgun if possible. For original cabinet you need to use longer ribbon cable (depends on where you want to place controller connectors) with appropriate connectors.
Please remember that you will also need 6 button games to play, so this needs some 6 button games burned on eprom. Best way for this is hacking original cartridge or having made custom cartridge for it.
glstar
160CR
I understand.
Yes of course original megatech games are 3 buttons only.....
Yes, clear.
Nes4life
1,134CR
I'm getting one of these from purple. Just need one more interested person to make it happen.
Can't wait to get a light gun hooked up to my mega-tech... no chance of using the dedicated gun port as it's just undocumented. Nice little project to breath new life into the cab.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
your gonna need to wait i'm fixing the boards design LOL
most prob be done before I go to bed if im lucky
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
Nes4life said:
Lol nice one! Awesome to see you get involved mate.
without fixing those IC would never fit in the holes
im just going through it and making sure all holes are the proper size
40 mils
currently they are 20 mil and minimum to get an ic in is 29mil
purple
-1 (0%)
1CR
Here is what it looks like after Silverfox0786 fixed the holes, silkscreen and removed some wasted area.
I'm
also happy to announce that this is smaller and it affect the overall
price £4 reduced. Thanks for Silverfox0786 made this possible again. Now
it is ready for fabrication.
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
One thing I will advise on is to use the correct type of IC
on many occasions the switch over of LS and HC doesn't matter, but sometimes it does
just to be safe use the exact one on the actual Megatech
LS is Lower Power Schottky (10 Nano Seconds)
HC is High Power CMOS (6 Nano Seconds)
purple
-1 (0%)
1CR
Hi friends, after
silverfox0786 fixed the pcb's we are now ready to order pcb's. If you are
still interested, I'm now collecting money to send them fabrication. My
paypal is
erhanpurple@yahoo.com if anyone interested can you please send £38+£3 shipping total £41?
Thanks.
