Sega Mega-Tech 6 Button Mod
Hi everyone, since i’m new member of the forum i would like
to share one of my Project that keeps me
busy since december 2013, i think the title and the explains everything but
here is my story. I’ve met some very talented guy over spanish forums nickname
Giacomo Agostin, he is as intersted as me about sega mega tech but also is more
talented than me on electronics. J.
He is the one who figured out this beautiful mod. I dont have any knowledge
about designing circuits using kicad or similar software and i dont know
anything about how 74hc/ls buffers are working, i still havent completed mod but i decided to
share it here maybe actual design can
change in the future. I’m going to send it fabrication soon and it can be
useful for others. Giacomo, thanks for guiding me about it and sharing your designs
with us.
The six button mod is a little bit hard to explain it.
Basically you need to take off 5 IC from the Mega-Tech board and solder sockets
instead of them. Then you must plug a pair of PCBs over those sockets. The
signals that Mega-Tech uses to receive the buttons goes through the ICs and we
need to mix them from the ones coming from the Megadrive pads using AND gates
and a few buffers to prevent any damage to the board.
Here you have the PCB of the final boards (and another
one that I designed for another project). As you saw on the pictures I posted
on the forum, the 6 button mod is made on prototype board and it´s a little
different from the PCB on KiCad (I didn´t tested this one yet but I suppose It
will work perfectly).
If you want to make this mod, be very carefully taking
off the ICs and replacing them with sockets. I had some troubles to clean the
pads to insert sockets.
The ICs from Mega-Tech board that you have to take of
are all in line. An 74LS257, 74LS244, 74LS08 from the left side and 74LS257 and
74LS32 from the right side. Between them is an 74LS32 that you have to leave on
its place.
As you can see on these pictures, I used some
pin arrays and more sockets to raise the board. The buffers used in this board
are 74LS125, but the final board will use 74LS244 buffers.
Final Board
with us.
its place.
Final Board
