Help testing AC voltage with multimeter
Remoteboy
7CR
Hi,
I'm trying to test the AC output of a Hantarex US250 PSU. I have a multimeter that supports up to 600V AC just not sure what I connect to where.
This is the PSU. The four pin connector on the top provides AC voltage. Left two pins should be 135v. Right side pins just says Degauss. Do i touch the red pin of the multimeter against one of the metal pins and the black against one of the ground pins in the 9 hole connector below?
or do i read the voltage from the cable connector in this picture (below)? And again do it touch one of the connectors with the red pin and connect the other to ground on the PSU?
Thanks for reading. I'm a bit out of my depth when dealing with AC voltages.
6,093CR
Connect one probe to one of the voltage pins and the other probe to the other pin. That simple. No ground invloved. Doesn't matter which probe goes to which pin as it's alternating current.
Remoteboy
7CR
Thanks for that. Needed to check the voltages as having issues with my monitor not starting up. Fan spins up and then spins back down, neck doesn't glow. It's not the chassis as that's just been repaired. I'm only getting 116v from the 135v so I'm guessing that's the issue. Not sure how to proceed from here.
RaveN
1,325CR
The 135v is DC, not AC and can be as low as 120vDC and that's fine. Check my post to your other thread. Don't try to measure high voltages until your sure what you're measuring. The Degauss is AC and both can kill you if you're not careful.
Remoteboy
7CR
Thanks. I replaced the caps and tuned the resistor potentiometer and I'm getting a solid 135vdc now. The only issue remaining is I'm getting nothing on the +12vdc but not too concerned as i'm using a switching power supply for the lower voltage stuff.
r-type
633CR
The 9 pin connector is for the logic board section. That's all DC and should be the normal voltages you'd expect. The blue sticker on the left of your first picture should tell you what's what.
I wouldn't worry about testing the degauss side of things yet as that's not powering your monitor.
I had 180v from mine when I checked it, so I pulled it out and replaced with a JAMMA switching PSU and an isolating transformer to power the monitor. I think Gunblade repairs the US250s but it was quite expensive when I asked.
