Hi,
I'm trying to test the AC output of a Hantarex US250 PSU. I have a multimeter that supports up to 600V AC just not sure what I connect to where.
This is the PSU. The four pin connector on the top provides AC voltage. Left two pins should be 135v. Right side pins just says Degauss. Do i touch the red pin of the multimeter against one of the metal pins and the black against one of the ground pins in the 9 hole connector below?
or do i read the voltage from the cable connector in this picture (below)? And again do it touch one of the connectors with the red pin and connect the other to ground on the PSU?
Thanks for reading. I'm a bit out of my depth when dealing with AC voltages.
