Still not sure which transistor... HOT would be output transistor, but isn't that bipolar? The MOSFET is in the PSU? Either way, if it tests OK OOC, then you are probably measuring the resistance of the coil connected to it on the PCB.Thanks for the help, I took out the transistor reads fine connected it to measurement tool I’ve got it’s not bad. A couple of resistors are out of spec so am going to replace and see if that helps.
This.mains fuse blows?
check bridge rectifier, any diodes and ptc in primary section, dummy load the b+ line and isolate flyback pin 2 but a short after the secondary should not cause mains fuse to blow as its a switch mode supply so should go into ocp if any shorts are present
you will read short base/emitter in circuit with a HOT - put meter into diode mode, common lead to collector and then read to emitter and then base, should read like a diode
Sorry didn’t read this comment lol.mains fuse blows?
Can you also please tell me what the bridge rectifier and ptc is please thank you.mains fuse blows?
