HOT Mosfet issues
Robfry2
52CR
I did some measuring of D101 and the ptc in diode mode are these current readings many thanks.
Robfry2
52CR
Realised I had negative round the wrong way these are new reading plus I’m getting continuity diode 680 even though I’ve taken it out and it reads not damaged I’ve taken out a resister next to it because it was out of spec and will replace but should this cause this.
Robfry2
52CR
Tested bridge rectifier these are the results and removed the ptc and it rattles like there’s something loose don’t know if that is a good thing or not.
gunblade
9,148CR
I don't like the reading on the bridge but there again i don't have a b and q multimeter
ptc should not rattle
i would replace the bridge and leave ptc out for time being
Robfry2
52CR
Thank you can’t seem to find a replacement ptc or alternative I take it it doesn’t need to be there in circuit?
Would this be a compatible rectifier?
Robfry2
52CR
Ok I replaced parts and removed the degauss chip and now am getting this issue. Is it a matter of getting a degauss wind or something not achievable thank.
tb2000
3,585CR
Yeah as Grant says, new ptc. It does look like the deflection yoke has perhaps moved back a bit causing quite a bad purity problem, but if it's not been touched then it's down to the ptc. Might take 2 or 3 goes with the new ptc (so basically switching on, waiting a few seconds, then switching off and waiting perhaps 10 minutes or so for the ptc to cool) before the picture is back to normal.
Robfry2
52CR
Ok thank you but I can’t find a replacement for this ptc is there a part that can replace it
Robfry2
52CR
Are ptc specific to the chassis or can you replace with any ptc with correct pin configuration thank you.
gunblade
9,148CR
degauss wand would probably do the job, better to get a ptc though, seem difficult to find now. I know donberg have some and so do cricklewood electronics
