Many thanks I will replace parts and fire up and update the thread 👍ptc1 would be a modern alternative but you can leave it out the circuit as its only for degauss
bridge you linked to is correct
Are ptc specific to the chassis or can you replace with any ptc with correct pin configuration thank you.Yeah as Grant says, new ptc. It does look like the deflection yoke has perhaps moved back a bit causing quite a bad purity problem, but if it's not been touched then it's down to the ptc. Might take 2 or 3 goes with the new ptc (so basically switching on, waiting a few seconds, then switching off and waiting perhaps 10 minutes or so for the ptc to cool) before the picture is back to normal.
No this is the only one, will a Degausser wond do anything or will I need to replace the ptc.do you have any other monitor chassis kicking around
