JAMMA Cab PSU Problem
sapporo46
70CR
Hi
Picked up a cabinet last week and I think there's a problem with the PSU. Upon power on the monitor comes on and the marquee lights up, but there's no other activity. I tested the JAMMA harness for +5V and on both pins 3 and 4 the voltage is jumping between 10 and 12? Also the LED seems to be flickering and it's making an odd sound - see video footage here.
There seems to be no life on +12V either, although I'm not sure how important this is?
So before I buy a replacement could someone please advise:
  • What's the likelihood of this PSU having failed?
  • Why didn't those voltages kill my PCB? I've tested it on my supergun and it's OK.
The cab was confirmed working when it left its previous owner, so I'm wondering if it's taken a knock in transit.
Any other input would be welcome, I've a good general knowledge but not a lot of experience.
Flinnster
The Dino King
29 (100%)
2,566CR
12v is used mainly for audio circuits, but also in your cab for things like lighting and coin doors.
12v shouldn't be on pin 3+4 at all. Sounds like the 10-12volts is the pin f / 6 connections crossing onto pins 3+4. Check no wires or soldering at your jamma edge are creating shorts, and that your connections at the PSU terminals are clean and there are no fraying wires.
You might also want to give the cab wiring a cursory check, making sure that everything is connected cleanly too - no buttons or sticks with exposed terminals touching the control panel metal etc.. and nothing on the coin door area shorting out.
Measure the voltages on the screw terminals of your PSU itself (between 5v + ground, and 12v + ground - make sure to avoid the live incoming mains terminals when you do this!).
If the voltages on the screw terminals of your PSU are all over the place, then yep, it's likely on the way out - although I can't explain in that case why it would be fine on a supergun (again, some bad wiring within the cab perhaps).
Perhaps for the sake of £20, get a new PSU for your cab and leave the existing for the supergun where it works ok.
For the sound.. stand well back?
sapporo46
70CR
Thanks for the reply Flinnster.
What I meant was my PCB was fine, despite having 10V+ delivered to the 5V pins. The PSU hasn't been out of the cab since the day it was made, by the looks of it! The supergun uses an ATX power supply.
There's some pretty nasty looking wiring on the JAMMA edge, I'll post some pics to illustrate it.
Flinnster
The Dino King
29 (100%)
2,566CR
Ah fair doos. I had a PSU recently that I suspected was causing me interference on the monitor. Turned out it was just dodgey wiring (I only found the offending bad wires when switching the PSU for a new one). Can quite often be the way, especially if you haven't wired the cab yourself so don't know it back to front :)
Flinnster
The Dino King
29 (100%)
2,566CR
Well while your jamma edge connector there might not be the most sparkly thing ever, I can't see anything too bad with it.. I've seen far worse to be honest!
OK you need to check not just the edge connector, but also the terminals at the power supply, and follow them back around the edges of your cab, making sure you have no frayed wire etc..
Also worth checking the underside of your control panel where the crimps connect to the buttons and sticks, and the back side of the service panel, while you're in there.
