LCD Supergun
peterbudduk
18CR
[ukvac] LCD Supergun
Do any of you guys have experience in building a Supergun-type-affair
with a built in LCD Monitor?
The price of these monitors is coming down sufficiently to make this
viable.
In my opinion the main issue is whether the output from the gameboard
is good enough for an LCD monitor to sync to (they may be more fussy
than ordinary monitors).
Also some LCD monitors do not have an RGB+sync input but will accept
PAL/NTSC so I suppose a side issue is whether those PAL/NTSC converter
chips do a good job with poor signals.
Any views gratefully received.
Peter
Apply for a NextCard credit card: Save Money with a low intro rate and
no annual fee. Make Shopping Easy with Safe Shopping Guarantees, 1 Click
Shopping and Double Rewards. http://clickhere.egroups.com/click/448
eGroups.com home: http://www.egroups.com/group/ukvac
http://www.egroups.com - Simplifying group communications
5,287CR
[ukvac] Re: LCD Supergun
pbdpc> Do any of you guys have experience in building a Supergun-type-affair
pbdpc> with a built in LCD Monitor?
Now, if gameboards became as small as monitors have become, we could
have a handheld arcade machine!
Hang on, isn't this the gameboy? :)
Chris
DATA Imported from archives: originally posted by Chris White (chrisw@insnet.net)
5,287CR
If i've read my rgvac deja stuff correctly then I don't think that you could sync correctly
to a VGA monitor (either cathode or LCD) however if you buy a LCD TV type thing (Maplins
are selling a 4" display in their current sale I think) then you should be able to connect
to the arial socket thing (whatever it's called). A SCART socket is obviously a better bet,
but I don't know whether these come as standard on a portable unit.
If you're serious about this then check out deja news for the VGA threads in rgvac for a more detailed
summary.
Chris
DATA Imported from archives: originally posted by Chris Ahchay (chris.ahchay@virgin.net)
peterbudduk
18CR
I wasn't thinking of using those flat screen VGA monitors (too
expensive anyway) but, as you suggest, I was thinking of using the ones
that are available in personal TV's. Those sorts of LCD monitors are
also quite easily available in the OEM market, some accept composite
video, some can even accept analogue RGB+sync. Whether I use a hacked
personal TV or an OEM module will come down to a question of cost.
Peter
<002101bece17$63f01280$1b46a8c-@ahchay> wrote:
original article:http://www.egroups.com/group/ukvac/?start=993
type thing (Maplins
> summary.
> Cheers
> Chris
G
Guests
Guest
I only have experience with the VGA screens but wouldn't resolutions and
scan rates be a bit of an issue ?. The VGA displays are very fussy. In my
experience LCD's aren't that great at handling fast moving objects,
something else to consider. I would be interested to hear the results of
any experiments. Imagine how much lighter your average JAMMA cab would be
if you fitted an LCD screen :) .
Cliff.
> From: peter.budd@dial.pipex.com
> To: ukvac@eGroups.com
> Subject: [ukvac] LCD Supergun
> Date: 14 July 1999 15:04
> viable.
> Peter
GET $10 OFF ANY ORDER @ healthshop.com! No min. purchase req.
Save on vitamins & supplements. Use coupon code: EGROUPS99
at checkout. http://clickhere.egroups.com/click/463
DATA Imported from archives: originally posted by Clifford Poole (xov51@dial.pipex.com)
