Let's fix Asteroids Deluxe
4,058CR
If anyone has any input then feel free to chip in!
I'm wondering if it could be monitor based? Or (and I hope not) given that I've replaced / soldered some components in the analog output section it could be some bad soldering on my part, or even a poor quality socket or something. I'm not entirely convinced of the quality on the last batch of sockets I ordered.
I hope we can sort this out remotely because I'm not doing arcade stuff any more - I've stopped
If we can't sort it out though I'll refund anything that was paid, including shipping.
Ronnie Dent
1,206CR
Thanks guys,
I don't think it's the monitor but then what do I know! One of the dac's was replaced and the other was put back but in a socket, could that have failed?
I do have some gear logic probe etc and willing to follow instructions, I could also connect it to x y on my scope to see if it display correctly on that?
I won't have any money back from you Martin that's for sure!
Put that screen on hold for me Oliver please
Cheers Ronnie
Ronnie Dent
1,206CR
Right back to this today, hooked it up to X Y on the scope and the picture is the same so that rules out the screen, as far as I can tell the sockets and the chips are all good.
Are there any other voltages that might cause it to display bad? apart from the 5v, think is the grid in test is good so I doubt it's a voltage issue!
Ronnie
bonehead
I'll get pix tonight
50 (100%)
1,729CR
I can't help with pcb repairs but I am sure it's not voltage as you say the grid looks good.
Just a guess but i would say possibly vector generator. I have had similar problems with a board of one a couple of years ago.
I am sure others with total knowledge will chip in later. It's a lovely hot day so I guess people won't be logging on till tonight. I do hope you get this sorted as you are almost there.
Steve
Ronnie Dent
1,206CR
Steve
Thanks Steve, would that be one of the dac's? Martin fitted one new one but the other was removed and put back in a socket, apart from the glitches it's fully playable
Cheers Ronnie
bonehead
50 (100%)
1,729CR
I am not too sure, sorry.
The tech people on here will be able to help. If you can't fix it yourself I am sure you will be able to get it done.
I have an ordinary upright asteroids which I live to bits but now also have a deluxe but so far it's completly untested so I will be watching your posts for tech answers.
All these cabs break at some point so don't get disheartened, I had a meet 2 months ago and 5 machines broke that night!!!!! Still haven't got them all working again but I will given time.
Hope you get it sorted.
Mitchell Gant
888CR
Definitely a vector generator fault, not wrong voltages and almost certainly not either of the DACs at fault or you would not see such a nice diamond test mode grid.
I'm puzzled at the text being all jumbled up, but there are specific parts of the vector circuit that deal with alphanumerics (the text and scores) in the vector timer section. Or could be the stack part causing subroutine faults that the text uses a lot of. If you download and look at the schematics PDF you'll see a section named 'Program counter', my wild guess is it could be something in there, maybe one of the 74LS670s.
Sorry, I know that probably doesn't help you much though.
Equites
Chief Sheesher®
35 (100%)
3,329CR
I have to agree with Neil, likely one of the counters in final section. They should be around four of them right near the DACs.Equites2015-08-09 00:03:01
Ronnie Dent
1,206CR
Thanks guys, anything is a a help no matter how vague, it's a shame as Martin has done a lot of work on the board clearly. I will have a look at the schematic in that area see if the probe finds any dead pins or report back the results here as I will probably not understand what I should be seeing with the probe.
Thanks Ronnie
Ronnie Dent
1,206CR
Right I looked at the schems at program counters and probed all the chips there in test screen, just noted any pins apart from vcc and ground that were stuck hi or lo here are the results
J3 LS670 pin 2 lo
k4 LS191 pin 4 lo
D3 LS74A pin4 hi
F4 LS193 pins 4 and 9 hi pin 10 lo
H4 LS193 pins 4 12 13 hi pin 14 lo
J4 LS193 pins 4 5 12 13 hi pins 6 14 lo
Not sure if these readings mean anything probably correct? Am I right in thinking the Dac's are near the front of the board near the bottom? If so none of the above cheats wehre near those.
Thanks Ronnie
4,058CR
OK, just had a small catch up, so some more or less random thoughts...
Can you check what pin 12 of J5 is doing please? Although on the face of it pin 2 of the 670 @ J3 did not ought to be stuck lo I have a feeling it's normal. What does it do when it's not in test mode? This is from memory but I have a feeling that in test mode it's normal for AD11 to not toggle. But I want to make sure I'm not barking up the wrong tree. As I'm typing this, I've now thinking it could be DVY11 that doesn't do much in test mode!
Anyway, it's pretty rare for the 670's to die. Not unheard of, I bought some about 12 years or so back because I found a couple of dead ones but I can't remember the last time I saw a bad one.
Pin 4 on all of the 193' SHOULD be high. On the schematics "P,Rxx" means "Pull Up resistor XX" and thus that pin is tied to +5V Likewise pin 13 is disconnected on them all. So again, not surprised they're not doing anything. Pin 12 is the carry. Not sure if that should be active or not. Will depend on the design. Again, worth testing what's happening in game mode. Remember test mode doesn't do a great deal apart from display the same static image over and over.
I would be slightly suspicious of pin 9 on F4 being permanently high (if it also is in game mode as well) since that is AD3 of the address being pushed / pulled to the stack (counting from 0) so you'd think that would be doing stuff. If it doesn't toggle in game mode either then suspect that. In which case check what H5 pins 4 & 5 are doing. Pin 4 is the input, pin 5 is the same signal on the output so they should always be the same (a 367 is a simple tri-state buffer). So if you have input activity and no output activity desolder and check the 367, BUT, it could be that the output is being held by the next chip down the line, the 193.
Definitely sounds like an area to check though. Problem is whether you have the chips and the means to do so.
It's unfortunate for sure but this stuff can happen, not just when the board has been sat for a year but also it could happen just from one day to the next. This whole business of burning testing a board for hours on end is pretty pointless in my opinion. The board will suffer the most stress (assuming nothing catastrophic happens of course) during power up and down because that's when the power supply is not stable and when surges are most likely to occur. So we could "burn test" a board for days and it run perfectly, turn it off and then the next time it is powered up, *pop*.
It's a pain, but that's life with 30+ year old chips sadly.
Ronnie Dent
1,206CR
Hi Martin, sorry been away for the weekend, I will sift through that this week and report back, I doubt I will have many of the rarer chips but desoldering and fitting new chips or sockets is not a problem for me. never thought of putting it into play mode before checking pins, in game mode it plays but asteroids are jerky and when hit turn into dots or small lines also base ship is 2 lines and UFO's are mostly flat lines, writing is jumbled up.
Thanks Ronnie
Ronnie Dent
1,206CR
Right just checked those pins in attract
J5 pin12 is Hi Lo solid
F4 pin 9 is Hi Lo solid
H5 pin 4 and 5 are Hi Lo solid
So a bit of a red herring on my part sorry, not sure what else to check?
Thanks Ronnie
