Let's fix Asteroids Deluxe
Ronnie Dent
1,206CR
Yes well above my limited knowledge lol!
Had it rigged to my scope on X Y this morning and it seems it will at times show something on the scope, what confused me was at times it would also coin up and play either blind or with some display without disabling the watch dog, I think I will have to put it to the side for now until I have some cash to either replace or get it repaired. Will concentrate on restoring the cabinet as have new vinyl for the sides as this is a woody from Ireland with no side art.
Martin (guddler) you helped me back in 2012 on jamma plus when I had issues with it then lol. It seems jamma plus is more modern stuff orientated these days!
Once again thanks for the replies and advice, if anyone knows of a repairer for this board please let me know, I do have someone in mind but will need to wait until I have the dosh
Ronnie
DanP
Administrator
2,232CR
One other quick long shot you can try. Remove the pokey and see what you get. Sometimes the pokey can affect address busses pretty badly when it dies. Without it the board will still run both in game and test mode but you'll be missing some sounds and the asteroids random starting positions.
It's a long shot but so quick to test it's worth a try.
Dan
Ronnie Dent
1,206CR
Thanks Dan, is that the chip same size as the CPU ? Have stripped the cab now removed psu and screen etc but will give it a try when rebuild it
Cheers Ronnie
Ronnie Dent
1,206CR
Thanks again Dan, been quoted £100+parts+postage for repair, thought I might be able to source a board or a piece of test equipment for that money?
Cheers Ronnie
4,058CR
Wow! Do tell who's quoting that much. That's a LOT of money for a board repair. I'm on my way out. Drop me a PM - I'll fix it for you as long as you understand that I won't from that point on be your personal contact for board repairs. That probably sounds harsh, but it's what generally ends up happening and why I tend not to repair stuff any more!
Ronnie Dent
1,206CR
Thanks Martin PM on the way. And I would never assume that of anyone who was good enough to help me out, would always look to return a favor if I could
Cheers Ronnie
4,058CR
Just a very minor update on this. I had to go up the shed and finish a few things off this evening and since i'm not about for the rest of the week I wanted to at least get the board out of it's box and onto the bench.
So, just to pretty much confirm what we've already said (with one exception), with L5, pin 1 clipped it will play blind, without, it resets. I can't get anything out of the diag step pin. Pokey removed unfortunately not helping.
I need to double check the diag step thing when I have a bit more time, I may be attempting that all wrong, or it's possible it's not even implemented on Asteroids Deluxe. I know it is on Asteroids.
SO, I said "with one exception", and that is that the continual reset that we get with L5, pin 1 connected is not the rapid reset I was expecting, it's a gentle, 1 second bark of the watchdog. Therefore, I'm quietly confident that while it is certainly an issue on the DVG side of the board (because it plays blind without that side running), I don't believe it's locking up hard like it would if it was a state machine issue. So if we're "lucky" (if you can call it that) it may be a counter or one of the function stack RAMs. That's my initial thoughts anyway. And I am tired so I could be way off.
Will update in a week or two when I get some time to sit down and go over it properly...
Ronnie Dent
1,206CR
Great stuff Martin, thanks for the update, I'm nowhere near ready for the board anyway, enjoy your time away holiday I hope!
Thanks Ronnie
4,058CR
Chance would be a fine thing, nope, work.
Guys, yeah, I thought that was insane money which is why I stepped in this time round (not something I often do). However, it may be that the person reads this forum and we all know that DVG issues can sometimes be a bitch to sort out. That's all well and good if you're doing it privately and are therefore not on the clock. If you're doing it commercially and therefore I would assume expect any board repair to take no more than half a day or maybe even a day then I guess the figure gets put in perspective.
There will come a point when we don't bat an eyelid at those kind of figures. And if I'm honest, I don't think we're a million miles off that point, but to those of us that can do repairs ourselves, we just look at these things in a different light.
RGP
Meeter & Greeter
2,039CR
And regrettably, eventually those professional board repairers are going to want to stop doing it.
4,058CR
Right, finally had a major tidy up over the last few days so I could get to things properly and tonight made some nice progress with this.
First thing I did was check out that diag step against one of my working PCBs and it appears that although the pin is there, Atari doesn't appear to have implemented the code on Asteroids Deluxe so not being able to run the advanced diagnostics would appear to be a red herring. So I load up my Fluke to double check all the RAM and ROM. Surprisingly I find that I've not written any scripts for AD before so I quickly copied my Asteroids UUT and modified my CRCTest, ROMTest and RAMTest programs to match Asteroids Deluxe (there's an extra program ROM and Vector ROM).
Not surprisingly the ROMs were fine. However I was quite taken aback to find that the Fluke reported two of the four vector RAMs were not OK. To be sure I swapped them out and it was indeed correct. Here's the second of them reporting a dead memory cell:
Sadly however, replacing these two RAMs didn't get me any further.
So, que the usual probing about and basic grunt work that goes with the territory of a vector generator fault. I was still pretty convinced this was not a problem with the actual state machine itself as when that's faulty it locks up good and tight into a loop and you don't really get much to go on. After going over the state machine I pretty much confirmed that it was producing what looked like reasonable outputs for the inputs so I moved to look at the function stack and address counters.
I started to see some odd behaviour here and before long I managed to find a 74LS193 that didn't look right. I confirmed it with my logic comparator and piggy-backing a known good chip on top showed good promise so I cut the 193 out and replaced it.
So now we have this...
I guess it's not obvious from that picture but now the resets have gone and the game will play, also test mode works just fine but clearly we have no X output. Additionally I'm suspect of the Z output too as when I put it on a real monitor the spot killer is on so it's obviously not happy about the Z signal for some reason.
So next step is to investigate the output section and maybe the X position counters.
Ronnie Dent
1,206CR
Wow Martin very involved! looks like your making good progress though, I'm surprised so many things can go wrong over a period of no use! That's the main reason I got rid of my classic board collection many years ago. Thanks for the update, will need to crack on with the cabinet.
Thanks Ronnie
4,058CR
Right, decided to have another play with this tonight rather than just plonk in front the telly.
There's good news and bad news!! First the good news:
It's working.
Now, the bad news!
As you can see from the following pic I've replaced quite a few ICs in the analog output section
I can only assume that the board has taken a jolt in the power department, so please, please, please check your voltages and AR board before going any further. Also, sadly, one of your DACs is bad and I don't have any spares. The board is currently using one of the two from my own Asteroids Deluxe board. I've put up a wanted on here or, of course the board can be returned with nothing in that socket and you can source your own.
And sadly, it get's worse. The Pokey is also not working. Just gives ERROR in the test screen and all of the asteroids are on top of each other. Those I do have though so it's not really a problem. I need to work out how much they are though.
And finally, any idea how you reset the high scores? I couldn't see it in the manual. I'm not sure if the EAROM is working or not. If it's not then I also don't have any of those spare either! But I've not looked in detail at that circuit yet.
SO, very much making progress but I'm afraid it's a mixed bag
Ronnie Dent
1,206CR
Great news Martin, thank you so much. I thought it might be just one IC! no such luck, still no desperate rush here to get it back, is there anything else that might have one of these dac's? such as old console etc.
Thanks Ronnie
4,058CR
No, some early Atari boards, and AD is one of them make use of what's called an EAROM (electronically alterable read only memory) It saves the top three scores, however to do so it needs a funky voltage of -29v so it's not at all uncommon for them to not work. On top of that, they only have a limited lifecycle. For one variant of the chip it is 100,000 erase/write cycles, for another, 1,000,000.
Now clearly that sounds like such a large number that it's not worth worrying about but that's only an intended typical target number and when you consider that erase/write occurs AT LEAST each time a score is saved then the 100,000 one could be getting long in the tooth by now. Probably the 1,000,000 not so much.
I tend to always remove them while working on boards and put them back in at the end. I have in the back of my mind that they may do a write on PCB power down but I'm not so sure about that to be honest.
[EDIT] The statement about when it writes to the chip may not be correct. It may store scores in normal RAM and transfer them at some point? I don't know, i'd have to look stuff up to be sure.
guddler2014-06-24 10:55:54
