[ukvac] Monitor Connections
I've got a couple of simple questions about the connections to the
monitor in my cab:
There are several wires which go from the JAMMA loom to the monitor:
Red, Green, Blue - Colour signal lines
Yellow and Black ?
There is also a separate connector with a black wire and a white wire.
Can anyone tell me what these are?
I assume that the yellow and black are power and ground, but what about
the white and black?
Secondly, if I need to cut these wires to remove the loom or the
monitor, is it safe to reconnect them with standard connector blocks, or
would you use a more secure connection (crimped connectors or
something)?
Cheers,
Nige
DATA Imported from archives: originally posted by Nige (nigel.scott@rdel.co.uk)
monitor in my cab:
Yellow and Black ?
something)?
Cheers,
Nige
