Monitor Connections
5,332CR
[ukvac] Monitor Connections
I've got a couple of simple questions about the connections to the
monitor in my cab:
There are several wires which go from the JAMMA loom to the monitor:
Red, Green, Blue - Colour signal lines
Yellow and Black ?
There is also a separate connector with a black wire and a white wire.
Can anyone tell me what these are?
I assume that the yellow and black are power and ground, but what about
the white and black?
Secondly, if I need to cut these wires to remove the loom or the
monitor, is it safe to reconnect them with standard connector blocks, or
would you use a more secure connection (crimped connectors or
something)?
Cheers,
Nige
Your use of Yahoo! Groups is subject to http://docs.yahoo.com/info/terms/
DATA Imported from archives: originally posted by Nige (nigel.scott@rdel.co.uk)
5,332CR
RE: [ukvac] Monitor Connections
Most likely the Yellow is Sync, the Black is Video Gnd.
And the white and black are Power.
At least that's how it is on mine :)
Regards
Chris
DATA Imported from archives: originally posted by Chris Priest (chris.priest@inter.net.uk)
5,332CR
Re: [ukvac] Monitor Connections
Makes sense - Cheers Chris. The system I use at work has the sync on one
of the colour wires so I hadn't thought about it being separate...
Nige
Ordyne
1,282CR
How small and how many pins is the Din ?
It sounds like composite / Svideo so far which isn't much use.
Maybe best if you take a picture of the connectors.
Cheers,
Craig
netdent
21CR
thanks Craig, i think you might be right, fairly modern monitor tho
have attached a pic, not sure if it will work on the group.
Ronnie
Cheers,
Craig
