Monitor Issues
JAG555
129CR
Hello,
I am having some issues with my monitor and I am hoping someone can help please?
I have a Sega Blast City, which was bought with the monitor fully working in the vertical position. I got it home and changed it over to horizontal position. Here are where the issues started. Once rotated, it would not fire up and I was getting a horrible cracking from the anode / diode cap (excuse the lack of knowledge, I am on a learning curve). It sounded like it was trying to fire up, but couldn't. I know these things are dangerous, so I took care and managed to push the cap around and that appeared to do the trick. The Blast was then put in my garage while my arcade room was being built.
However, I just took the Blast out of storage today and the monior wouldn't fire up. This time no noise from the cap, but I did the same thing and it came on. However, it went off again later and hasn't come back on.
Any ideas? I removed the cap and it looked like it might be missing a bit from one side, but then I don't really know what they look like anyway? Maybe it just needs pushing in, but I should really discharge it first before messing around. The rubber cap is also not down on the tube properly, it is sticking up around the edges. I will try and get some pictures.
Any help or advice would be greatly appreciated, as it's so frustrating......
John
JAG555
129CR
On further inspection, it looks to me like the anode cap has broken off partially, as from others I have seen mine l looks incomplete.
Any help greatly appreciated.
DABYX
109CR
I'm no expert but I would not touch and fiddle with the anode anymore before discharging it!!
And if it looks broken, replace the flyback (which is what the anode cup is attatched to) It will have to be a particular make for your model which I'm sure others can tell you.
If you mean broken off as in not seated properly against the monitor and not actually broken, discharge it first then again and then clip the two clips securely ananmake sure the cup is on tight before switching back on again.
Can't stop saying though, discharge it. Properly. Lol
JAG555
129CR
Many thanks for the reply and I think that is very wise advice! I think we got away with it last night through being careful and dumb luck!
Its so frustrating though as it worked for a little bit and therefore, I hope it is just the clips.
I will get some photos tonight.
DABYX
109CR
If it is broken and you do need a new flyback, don't worry too much. They should be easily available and I've replaced one (not an electrician or anything!) Or you can get a techie to fix it for ya. (Gunblade on here is a fine chap!)
JAG555
129CR
Many Thanks for the reply. I am just waiting for some clips and then I will discharge the monitor and investigate. I wonder if the Blast City monitors might be self-discharging, as we actually had the anode out yesterday. However, better to be safe than sorry! I am hoping it's just an issue with the clips.
obcd
3,830CR
Even if it is discharging on it's own, the tubes seem to recharge a little again if you leave them with the anode cap disconnected. A perfectly discharged tube (to remove the anode cap) can still produce a small spark if you reconnect the anode cap the day after (and bite you as well)
So, it's best to discharge again before you reconnect the anode cap.
JAG555
129CR
Thanks for the reply, I won't take any chances and make sure it is discharged fully.
JAG555
129CR
Quick update, I have taken some photos of the diode cap and taken the the model number. I cannot discharge the monitor yet, as I am waiting for the leads.
The monitor is a Toshiba MS-2930-S
The photos are on the below link
As the photos show, the anode cap is just not fixed to the monitor. It appears to be bending up at the edges. The monitor has static on the glass when it is switched on, but no cracking and no picture. I do also get a slight flash when the machine is switched off.
Any ideas what the issue might be? Loose anode?JAG5552017-01-28 20:02:16
DABYX
109CR
If it was me I'd discharge ;-) the monitor, remove the chassis, clean up that area on the monitor with isopropyl alcohol and replace the flyback on the chassis.
The cup looks a bit damaged to me.
phillv85
490CR
The problem you'll have here is that the flybacks are not available for these. It might just need the area around the suction cup re-greasing, it looks a little dry there.
JAG555
129CR
Thanks for the replies. I went to work on this last night. Discharged the monitor, but didn't need to (better safe than sorry!). Cleaned all around the anode and the anode cap. There is only one full clip intact, which was a worry and the rubber cap still keeps raising at the sides. However, I put some silicon grease on this and we are up and running now.
Monitor looks great. If the cap does come loose again, I will need to replace the Anode Cap, however the Flyback works fine. I will probably send it off to Grant in the summer anyway to get done.
Thanks for all of the replies here and also to Grant for all the help over messenger. This is a really helpful forum!
