MTC 9000 interlacing issue
big10p
Coins detected in pocket!
6,085CR
So, interlace modes jiggle up/down a lot - far more than the normal interlacing flicker. I can mostly remedy this by incresing the vertical back porch (I'm using CRT emudriver and arcadeOSD). However, there's still some scans that seem in the wrong order, or something - most noticeable when viewing text.
After the monitor has been on for a few hours and warmed right up, I have to tweak H/V sync to get a stable image again. Now, interlace modes display fine!
Seems like some component is failing/faulty? Anybody have an idea what might need looking at? The chassis has had new caps and lopt at some point, but I don't know how long ago.
Thanks.
big10p2015-04-25 12:38:11
big10p
6,085CR
Anyone? Calamity had this to say on the matter:
Anyway, if increasing the "vertical total" did help to some extent, and it is not a matter of odd/even number of lines, I think I have a theory of what's going on. It might be happening that the components are aged and because of this the raster takes longer to reach the top of the screen at retrace time (longer than in my MTC 9110), and it also takes longer to stabilize once there before drawing the frame. Because the quality of the interlace relies on exact length of the first line, if this length is abnormal it might produce a disalignment of the fields.
But which components cause this?
big10p2015-04-26 13:28:01
big10p
6,085CR
Caps all looked in good shape last time I had the chassis out, but yeah, maybe a closer inspection is in order. Do you know if there are any ones in particular I should look at?
Also, after reading some other threads, I was wondering if the HOT or VR might have something to do with this?
Cheers.
big10p
6,085CR
Right, after getting side-tracked faffing around with a load of other stuff, I'm going to get back to trying to fix my monitor issues.
The plan so far is to just replace all the caps and the HOT. Are there any other components that directly affect the horizontal scanning I should look at? The fact I have to tweak H sync when the monitor has warmed up, then back again when I cold start it means something's awry. Just hope Mr_goshki is right and a cap kit will sort it.
BTW, I've check the B+ voltage and it's a solid 132v, if that's relevant.
big10p2015-05-10 14:43:55
big10p
6,085CR
Well, new caps have made no difference to the interlacing issue. There were a few smaller caps missing from the kit, though - don't know if this is normal? I'll test later to see if it's helped with the issue of having to adjust the H/V sync.
I was wondering if the socketed IC (Phillips TDA2595V9) on this chassis could be to blame for the bad interlacing, as it seems it controls the monitors syncing etc. Maybe there's a newer version available? Clutching at straws here...
big10p
6,085CR
OK, back to this. The cap kit has sorted the issue with having to adjust H/V sync pots all the time. When first turned on, interlaced modes are still very jittery, but this all but disappears after the monitor has warmed up over a LONG time - about 6 hours, or so. Anyone got any ideas what might need looking at to solve this warm up issue?
joe34
448CR
im not sure what components might change/'drift' a bit when they've been on for a few hours but maybe someone could look at the mtc9000 schematic and have a think? sorry I cant help* as im not tech enough for something like this (ie. I don't know what parts of the mtc9000 monitor relate to 'interlace mode', or that is even a valid question
* ... but i'll have a think about it anyway
joe342015-07-23 16:17:38
big10p
6,085CR
I think I have the full schematic in the manual but really don't know how to read those things properly, TBH.
It just seems like some component (or components) needs to get really warmed up before it functions fully. I just don't know what that component might be.
Cheers.
big10p2015-07-23 16:26:46
joe34
448CR
hmm I had an idea but unfortunately I don't think it would prove or solve anything, but anyway here it is
do u have some portable heater or something to warm up that monitor fast
- if so, monitor from cold, you could get the monitor running, crank that heat up, and see if the interlace fixes itself in like 10 minutes instead of 6 hours
im not saying that's a solution of course, or if it will help with solving the issue. but still. maybe if you're bored or something
(sorry, I've really got nothing here
... but feel your pain, it's annoying when you are close to being happy with your setup but some little thing is stopping you from reaching your goal. I hope you can solve this problem m8, and if you do, please post the solution here)joe342015-07-23 16:44:30
big10p
6,085CR
Interesting idea.
Don't think I have a suitable heater, though - and like you say, it's not a solution. I did think that maybe the controller IC needs replacing or something, but that wouldn't really make sense considering it gets better once warmed up.
tb2000
3,578CR
Is it like a gradual thing where it gets better as it warms up or does it get to a certain temperature and then it pings into a perfect picture? There was a fix for Polo monitors I think that fixed "jitter" on certain games where you put a resistor between I think sync and ground. Don't know if it is the same for the 9000 though.
PaulSwan
ZZZ
1,118CR
Interesting, it's the first I've heard of someone using an interlaced signal with an arcade monitor. There's no mention of it in the Hantarex manual - are you sure it's supported?
Paul.
singy1uk
119CR
failing components can cause faults like this,heat = expansion so over time faults seem to correct themselves.so its possible that the ic is internally faulty or components like resistors are failing.also the ceramic disc caps could be failing.sorry i cant point to the exact components.but id test components around the horiz output stage and sync circuits.also chech for weak diodes.
edit: Then again i'd go with paul swans comment
singy1uk2015-07-23 19:10:50
obcd
3,830CR
Instead of warming things up, you could try the opposite approach and use some freeze spray to cool some parts of the pcb. If the defective component is cooled down again, the problem should reappear. But to be honest, I never was able to find an issue with this method. Obviously, you shouldn't spray on the neck of the picture tube and not on the LOPT either. (The spray is cooling down so fast that condens can occur on the components you are spraying.)
big10p
6,085CR
tb2000: it's a gradual thing. I did experiment with a resistor on sync/ground. Depending on the resistor I tried, it either completely cut the picture or made no difference.
PaulSwan: I'm using this with a PC+JPAC+GroovyMAME setup and others using the same monitor don't have the issue, so I assume it is - or should be - capable of interlacing.
singy1UK: Good point. I'd like to try and get hold of a replacement Phillips TDA2595V9 IC to try so I'd at least be able to rule that out. Anyone got one?
obcd: Interesting approach but as a bit of a noob at this stuff, don't think I'd feel safe spraying that stuff around inside.
singy1uk
119CR
You can get them on ebay thelittlediode seller sells them.i wouldnt spray freeze spray on a running monitor im sure that would not end well.
