MTC 9000 interlacing issue
pooman2084
Be Attitude For Gains!
26 (100%)
1,886CR
I have this issue on a Polo 2 with PC/JPAC and GroovyMAME.
It runs fine in my JAMMA cab, but varies between stable and epileptic in my NBA Jam cab. Temperature doesn't seem to make a difference to my symptoms.
CGA games work 100% with no issues, but the menus and med res games are generally horrible with the interlacing bouncing maybe 2 lines above and below. The setup menus are almost unreadable.
big10p
Coins detected in pocket!
6,093CR
Might be worth trying the fix tb2000 mentioned earlier.
Also, I was able to improve the interlacing by going into ArcadeOSD and editing the modeline of the interlaced modes. Try increasing the V Total.
obcd
3,830CR
Correct me if I am wrong, but does it actually make a difference for a monitor if you feed it with 240p or 480i. I mean, it's not like there are some components inside to determine if it's the odd or even frame that it's getting and adjusting some things accordingly. This would however mean that the picture should be jittery in 240p mode as well untill it warms up.
Does the jitter appears to be a vertical issue (defocussed horizontal lines) or do you have it horizontally as well? (defocussed vertical lines)
big10p
6,093CR
It's a vertical issue only - horizontal lines jitter up/down by 2 or more scanlines, instead on the expected single scanline. All progressive modes are rock solid, so no problem there.
big10p
6,093CR
Update: So, I fitted a replacement TDA2595 chip today (easy job - didn't even have to remove the monitor). Powered up and was greeted with the usual jittery interlacing. Wasn't exactly surprised as I didn't really expect it to make a difference... BUT, after a few minutes, the interlacing improved to the point where I was having to wait about 6 hours for things to warm up, before! In fact, I'm pretty sure the interlaced modes look better than I've seen them before, on this monitor.
Not sure if things are 100% as good as it should be but I'll settle for how it looks now, no problem. I'm, calling this issue fixed! Well chuffed - best £3.50 I've spent in a while!
Cheers all
big10p2015-07-25 18:28:07
gunblade
9,144CR
that ic should not really have affected the picture how you describe-unless this is in a socket and the contacts are corroded,this could explain a few things
big10p
6,093CR
Yes, it's socketed. A couple of the pins on the old IC looked a bit bent. I have removed it in the passed to clean the contacts but this didn't help with the issue. Not sure what's going on but just happy that it's improved things.
The new IC is just labelled TDA2595 while the old one is TDA2595V9. Don't know if this makes a difference.
big10p2015-07-25 19:26:19
joe34
448CR
nice one big10p
ps. as gunblade said, if the contacts of the IC are a bit corroded u could give them a clean with switch cleaner (spray the legs of your OLD IC chip with servisol super 10, and then put your OLD IC chip in/out/in/out/etc a few times in the socket (this will give the socket contacts a good clean)
then wait 10 mins or so and put your new chip in again
obviously don't do this process with your new chip, as putting it in/out/in/out several times isn't going to be good for it
big10p
6,093CR
Yeah, or maybe the solder just need re-flowing. Will replace the socket though. know where to get one? I don't even know what to search for. Might be on the parts list though, I guess...
