MTC9000 help
Purity
The Oracle
17 (100%)
2,999CR
Yes it was domed. I wasn't 100% sure if that was ok or not, from previous experience with MTC9000's. I do recall my last one might have been like that
Anyway I had a spare cap so I changed it. I can always put the original back if necessary
I took a video of what the monitor is doing and the noise, as I thought it might help
Ordyne
1,282CR
Yeah you changed it for no reason, they have a plastic cover on the top which warps, if that baby was splitting open you'd have one almighty kaboom.
The video sounds like you have a leak on the focus, you could possibly see where it is by turning the lights off but you may struggle with the monitor in the cabinet, to try an repair it I would always suggest pulling it out and working on it.
Also make sure your CRT ground to the neck board is connected and doesn't have a dry joint where the spade terminal solders into the neck board.
Id connect your video back up and see what the pictures like then report back and also measure the B+. If it all looks ok we can figure out why its shutting down but I have a couple of ideas already.
Purity
The Oracle
17 (100%)
2,999CR
The cabinet is in the garage, but it has a constant temperature of about 7-10 degrees, which I think should be acceptable?
It came from the Barn Raid, so I'm not sure what kind of condidtions it was stored in...quite possibly damp/cold?
How do you fix a focus leak?
I always make sure I have the neck ground connected. I will check the spade but I'm pretty sure it looked ok last time I had it out. I can always reflow the solder joint
I'll do another video with the lights off. What am I likely to see?
I'll also plug a PCB in and see what I get on screen.
Purity2014-02-01 18:20:06
Purity
The Oracle
17 (100%)
2,999CR
Powering up in the dark was a good idea!
I'm certain the hissing noise is arcing at the anode cap. I can clearly see it.
PCB looks fairly ok picture wise, but is upside down for some reason?? Monitor taken out and put back in the wrong way I'd guess?
One thing I did notice is that for about 3 seconds during the attract the picture split in half, and then returned to normal. Unfortunately I don't think I caught that on video
Purity2014-02-01 20:55:33
Ordyne
1,282CR
Try moving your scan coil plug into the other connector to flip your picture.
You're going to get some level of damp in any unheated room so you will get arcing at this time if year, especially where there is dust/gunk around the anode cap and focus cable at the CRT socket.
Can you measure your b+ and let us know what it is?
The picture splitting may be related to why the chassis shuts down with d10 in place but we need to know the b+ is ok first.
You could do with the monitor out of the cabinet, even on a black and decker workmate behind the machine is a thousand times better than trying to work on it as you have it as you can tell what's going on then ! :)
Ordyne2014-02-02 22:09:27
Purity
The Oracle
17 (100%)
2,999CR
I have a radiator and dehumidifier working in the room to make sure the temp is around 10 degrees and the humidity is 60-65% constantly
However there could be dust and gunk around the anode cap, as this came from the barn. What's the best course of action with this? Remove the anode cap and clean underneath and the cap with isoproponal alcohol?
The flyback on this is new (kindly purchased from yourself), so the focus cable on the neckboard should be free of dirt
I will measure the B+ and let you know the results
I'll also look at taking the monitor out. I'm just a bit limited on space, so it might be tough
Thanks again for your comments and help
Purity2014-02-02 22:24:17
Ordyne
1,282CR
Its ok for storage but even from 10 degrees your machines are going to warm up (especially the crt) and you've got a chances of moisture forming.
You can use IPA to clean the crt but just be careful not to remove the coating on the tube. Use high voltage silicon grease wont go a miss on the cap.
RGP
Meeter & Greeter
2,039CR
Great points Craig, wouldn't believe how many of the games i acquired had screen faults that were down to crud under the cap or around the receptacle - you don't always spot it until you discharge to remove for investigation.
Now its one of the first things I check on new monitors coming in.
Do you have a recommendation on the Hv silicone grease?
Purity
The Oracle
17 (100%)
2,999CR
Nice one Craig. I'll just gently clean the cap area on the tube, and the cap itself with some IPA
Edit ^ This is now done. I gave it a very light clean. It was fairly dirty on the tube and the cap
I've ordered some dielectric grease:
http://www.ebay.co.uk/itm/380370452070?ssPageName=STRK:MEWAX:IT&_trksid=p3984.m1423.l2648
Hopefully this should be suitable?
Ben
Purity2014-02-03 22:28:31
Purity
The Oracle
17 (100%)
2,999CR
I've applied a small covering of grease to the tube cap area, and the cap itself. I am still getting arching. The cap area on the tube looks fairly worn. I took a picture and will upload shortly.
Picutre is the correct way with scan coil connector change, and looks fairly stable, again image to follow.
I took some readings at SP3. On power on it was at 145v DC. As the arching noise started it jumped to around 156v DC and was fairly stable around that figure
Equally on SP4 it started at around 110v DC and when started to make the arching noise jumped to around 127v DC, and was fairly stable around that figure
Purity2014-02-04 19:11:04
5,410CR
That is your problem chap, the monitor has been left arching for a while and the voltage has taken the coating off and it needs that, the grease would help, but would look at a way of coating the tube again.
Check the cap too as if the tube looks like that, the cap probably has burn marks in it too
Bods2014-02-04 19:46:17
PaulSwan
ZZZ
1,118CR
Don't also forget to clean any metal oxide residue off the metal socket on the tube (inside it) so there is good electrical contact between the metal plug on the anode cap. If the new fly is a NOS one, it may also need a clean.
Paul.
Purity
The Oracle
17 (100%)
2,999CR
The cap is fine. It's a brand new flyback. I've cleaned and greased it. There's no burn marks
Agree with the coating at the tube. It is screwed. I've only noticed how bad it is this evening. Any suggestions on how I can re-coat it, or is it new tube time?
What's the best method for cleaning the metal oxide residue off the metal socket inside the tube?
Purity2014-02-04 20:42:48
Ordyne
1,282CR
The grease you linked to looks a bit iffy, I don't see any high voltage rating unless I missed it?
Can you reconnect d10' turn your horizontal frequency pot fully anti clockwise and see if the monitor powers up, if it does turn the pot and see if it shuts down when you alter the sync. Also try the same thing but start with the pot fully clockwise before you power up.
Purity
The Oracle
17 (100%)
2,999CR
I'm struggling to find any HV grease. The seller of the previous grease I bought was unsure of whether it would be ok with the HV. I've applied some anyway, and can always reapply a new option. Any recommendations?
Can I do anything about the anode cap area?
Purity
The Oracle
17 (100%)
2,999CR
Thanks Craig. I have been looking at ways I can make that anode cap area non conductive. Clearly it's conducting in the areas where the damage is
Have you dealt with similar issues in the past and what did you do? I assume you have never used Corona Dope :)
I'll clean the area and cap with IPA again and get rid of the grease, and order that stuff from Farnells
Purity2014-02-05 11:36:36
