Purity said:I'd really aappreciate it if you can tell me which ones I can solder back on, based on the out of circuit tests above?
I assume TR20, 21, 22 are ok?
No idea for TR17 and TR 19?
TR15 replace?
Ordyne said:Your b+ is bang on for no load, personally I'd lift one end of d10, plug the scan coil connector back in and power up to see if it runs.
I'd only use the light bulb to test for a psu fault, that doesn't seem the case and is extremely rare to see a load related fault on a 9000, plus you've had most of the silicon out and tested it already!
