Mitsurugi-w
PM me for CP3 SUPERBIOS!!!
http://youtu.be/cxW7zkXEW_A
Let me know if you have any questions or comments.
Alpha12013-10-04 11:37:16
ZedEx48K said:Personally I would of pre-tinned all the parts to be soldered, secondly you show an alternative point and on the other pad enough area to scrape and tin to connect a second temp battery while the main is replaced, saves all the hassle of working on a powered up cart![]()
Alpha1 said:Nice work, made your link clicky and also embedded it![]()
Mitsurugi-w said:ZedEx48K said:Personally I would of pre-tinned all the parts to be soldered, secondly you show an alternative point and on the other pad enough area to scrape and tin to connect a second temp battery while the main is replaced, saves all the hassle of working on a powered up cart![]()
Yeah. I realized I didn't pre-tin that one pad after I had already removed the battery. In one section I do show to pre-tin the pad beforehand.
You don't need to use the power-on method but I have done both and prefer this one. Years ago I tried to do the helper battery method and my success rate was only about 50%. I didn't know whether the cart was extra sensitive to the battery voltage when adding a second battery so I just began doing the power-on method. And is has evolved into this over the years. I have only been unsuccessful with one cart in the last two years and it didn't die during the actual swap. It died due to pure stupidity....![]()
Alpha1 said:The two carts I sent (mine and Porchy) should be with you soon. Tracking says they have hit the good old USA! Hopefully USPS isn't affected by the Government shut down - but probably is!!
forcefulfil said:Great vid dude!
thx for posting
IDCHAPPY said:Get yerself a new pair of piler instead of them rusty old things.![]()
Top video dude, I still think Ill be sending my cart to you though![]()
Mitsurugi-w said:IDCHAPPY said:Get yerself a new pair of piler instead of them rusty old things.![]()
Funny story. I've had those wire cutters for years. I actually used them to cut open the cable box where the cable comes into my house so I could install a MoCa filter. I then forget about them outside for about three weeks. I looked all over for those damn things. Then one morning I was taking a leak and I looked out the window and saw them out of the corner of my eye on the porch railing. They were rusty, or course, so I doused them with WD-40 and opened and closed them until they moved freely again. So I refuse to buy a new one until they are useless. lol.
