Nemesis - input problem
Fuzzy
18 (100%)
564CR
Hi all
As you know I have been very kindly loaned a Nemesis board
It's working great apart from one problem: The ship fires on its own constantly (very slowly).
My cab is Unigame wired with a JAMMA adaptor and I'm using a Jammaboards Konami-JAMMA adaptor, so there should be no problems there.
Of course I've checked the buttons on my cab, and they're fine, and the voltage at the board is around 5.07v. I've tweaked that a bit with no difference.
I've tried changing between 1 and 2 player controls on the dips, and again, makes no difference.
This is what I'm getting in test mode:
Any ideas, fellas?
I'm desperate to play one of my grail games!!!
RGP
Meeter & Greeter
2,039CR
First things first, if you disconnect your fire buttons on the control panel what happens?
I want to eliminate the physical side first before I take a deep breath and say....
... it sounds like an input buffer IC or surrounding control is being held constantly on. This might be as simple as a resistor has failed or the input IC has stuck pins.
I have to say that i've found this quite a common fault now as i've had a few boards go this way.
Fuzzy
18 (100%)
564CR
Thanks fellas.
Yes I tried it with the CP disconnected.
Is there any way I can check the ICs with a multimeter?Fuzzy2013-12-18 17:56:37
RGP
Meeter & Greeter
2,039CR
Hmmm, probably not, you need a logic probe at the very least.
According to the schematic fire 2 and 3 are at A7 and A12 respectively on the edge connector.
What you can do is check the two diodes and the two resistors with your multimeter.
On beep mode, check the continuity between A7 and one end of the non-banded end of each diode until you get a beep - that will locate the diode in question, then move your tester to be on each end of the diode (if you have a specific diode mode on the meter, select it now), if you get open circuit swap the leads, if you still get open circuit you've got a bad diode, if you have open one way and a reading like 0.567 then your diode is good - repeat for A12 remembering where the two diodes are.
Now you check the resistor pack, these pull the logic level high unless the switch is closed (in which case it goes low as the switch connects the circuit to ground to make contact).
You'll need to find the ground pin of the resistor pack in Equites' picture - by looks of it the left most pin, check its continuity to ground by beep mode and touching A17 - if you get a beep you've found the ground pin on the resistor pack.
Put your meter on ohms and some range that will read 220 and with one lead on the ground pin of the resistor pack work your way along the other pins to make sure all get 220 or at least some reading - something might be pulling them higher or lower but not according to the schematic.
That's about as far as you can go with a meter next is logic probe land and checking the input and output pins.
Do you have a basic logic probe?
Btw, B17 is also a ground pin you can use - saves you having to turn the board upside down etc.
RGP2013-12-18 18:24:29
simonden
20 (100%)
1,042CR
Just in case, make sure that the DIPs are set for single player control (DIP bank 3, switch 2 is off).
The Konami adaptor sends Parts 15 (Konami) to speaker (possibly ground) foir Gyruss, which is a 2p button in Nemesis. Don't have my adaptor here so can't check.
Fuzzy
18 (100%)
564CR
Thanks James.
No, I don't have a logic probe.
I'll try to do what you have described above.
