Outrun 2 - Square Wheels
Ordyne
1,282CR
Your Chihiro problem won't be in any way related to the feedback, you could be extremely lucky and have a bad/low psu. However if your chihiro has never been serviced then it's doesn't have any chance of surviving, it will lock up a couple of times right before it croaks and most likely kills the core board beyond repair.
corn
26 (100%)
231CR
I had the Chihiro serviced by a friendly chap near Newark ;-) I've not used it more than about 8 hours since then. You think it could be salvaged?
I've not powered the cab on since it started playing up again - I have the arse with it at the moment (as you can imagine!).
corn
26 (100%)
231CR
I'll check the voltages from the Naomi PSU tonight and make a note of what the status lights are doing.
I assume there isn't really anywhere else I need to check voltages?
corn
26 (100%)
231CR
checked the voltages:
5.19v, 12.19v & 3.51v
I've adjusted them down to what they should be and powered the Chihiro back on. Seems like it has taken a turn for the worse... I saw "initializing media board" briefly and then nothing. Status LED 4 is flashing and the bottom 3 LED's are on solid.
I'm guessing it is toast?
obcd
3,830CR
3.51? I would expect you need 3.3 there. Are you sure the batterie of your meter isn't on it's way out? Most digital meters tend to show a higher voltage when that happens, sometimes even before the low battery symbol shows up on the display. If the 3V3 truly was that high, it could indeed damage something on the main board. If it's a dual seat, you can exchange the media board between left and right to see if that's still working as expected. I read about people experimenting with xbox motherboards in a chihiro, but I have no idea if it's doable. Be aware that the MCPX chip is different and that a normal xbox motherboard only has half the memory. When the xbox is not a 1.6 type, you can solder extra ram chips on the board (but it's a fine pitch job) The MCPX is a BGA, so exchanging that is not an option for most of us. I think the assemblergames forum has some relevant discussions if this is the road you want to follow.
Obvious, the other road is finding someone here willing to fix it or exchange it for a working unit.
It will be double the price and half the fun of previous method, but it's more guaranteed to give the expected result in a shorter time period. As I said, I don't even know if the first method is a valid option.
Ordyne
1,282CR
Corn it way still be viable, send it in, if I can't fix it I won't charge you anything but return post.
In relation to xbox mainboards, that's not viable unless someone has done some work in the boot loaders that I'm not aware of, the mcpx and ram isn't the only difference btw. You could fit the correct mcpx and ram and it still wouldn't run.
corn
26 (100%)
231CR
Thanks - thats very kind offer. I'll get it packaged up and sent on to you.
I've got a Triforce Type 3 that resets are few minutes after booting - is that something you could potentially look at as well whilst I'm posting stuff?
silverfox0786
Beware the Hillman
47 (100%)
2,699CR
btw ordyne that's defo a tryforce error as we checked it at my house in my setup and still resets
my one does not reset
