Outrun 2 - Square Wheels
corn
26 (100%)
231CR
For some reason the force feedback on my OR2 seems to be playing up again. The steering feels "lumpy", like I have square wheels. It only happens when the force feedback is in action.
Tests of the force feedback don't complete either, they just hang after the wheel turns a little.
Anyone come across this before? I'll check for lose connections shortly and maybe apply some contact cleaner.
Any other ideas?
corn
26 (100%)
231CR
Yeh, figured its probably the nice and expensive I/O. I have a spare I'll try at some point, just didnt want to put that in if there is likely to be a problem elsewhere.
2,265CR
I've had a similar problem on an Initial-D cab, that turned out to be a dodgy connection on one of the cables from the drive board to the dash.
corn
26 (100%)
231CR
Hmmm, been through all of the connections, taken the dash out and checked the belt etc. Even sprayed all the connections with contact cleaner and still no luck. I'm now getting the occasional "centering error" as well.
I'm guessing that maybe the drive board isn't so well. I'll swap in the spare I have tomorrow and see where that gets me.
The motor I have in there looks pretty new - do these fail that often? I'm guessing the drive boards tend to fail more than motors?
retrorepair
26 (93%)
378CR
Drive boards definitely fail more than motors, not actually had a problem with this type of motor ever.
Make sure the ferrite clip is on the midi cable from the chihiro to the drive board and maybe even isolate that cable from the others to rule it out. I had similar problems without the ferrite clip myself.
Outrun2
Colonel Outrun
1,182CR
Motors are pretty bullet proof, but connections are where I'd be looking first- sometimes the pins come loose from the connectors especially on the dash looms as they often get pulled on and off a lot. Also make sure the midi cable from drive board to Chihiro isn't lying on any other components. Midi cables I've got from the States don't seem to be screened so even more important if you've got one of those!
Also worth checking the steering pot- check on the i/o test that it's within the tolerences and that it runs smoothly.
corn
26 (100%)
231CR
Thanks Chaps, gives me a few things to try tonight.
The cab is indeed a conversion - from a Club Kart so I guess its probably a good 15 years old?
corn
26 (100%)
231CR
Swapped the drive board out tonight and the feedback now works a treat. Any idea if faulty boards are cost effective to repair/can be repaired?
bbz149
26 (100%)
1,608CR
Probably people out there that do repair them, even thought about repairing my Scud servo board
not got round to trying yet as I have spares, but prob just a Mosfet or Opto that's gone!
I do have 2 spare Servo boards for sale if you need one, as useless to me now I have to use forking expensive Lindbergh boards in my OR2
corn
26 (100%)
231CR
Yeh, I guess I shouldn't complain too much - at least it wasn't a crazy expensive Lindberg board that died. WIll see how the funds are after xmas but might have a board from you if you still have them.
corn2014-12-24 23:40:47
corn
26 (100%)
231CR
I give up... Monitor dies before xmas, Force feedback dies a week or so later and now the Motherboard just freezes and now refuses to boot. I may as well go draw some money out, and just burn it in the garden.
griffo83x
30 (100%)
745CR
i know what your going through mate , i have had similar problems myself with these old sega racer's there like a bottomless pit when it comes to spending money :(
griffo83x
30 (100%)
745CR
ZedEx48K said:
And here'th begin my smugness of just sticking a PC inside one of these things
yeh something i might do in the future as long as i could get the ffb working otherwise it would be pointless .
griffo83x2014-12-26 22:50:23
Outrun2
Colonel Outrun
1,182CR
Ouch! Sorry to hear that- is it particularly cold in the gamesroom at the moment? These cabs don't like cold and damp- maybe check your voltages too.
I had similar issues with my iD cab a couple of years ago- chassis, gd-rom drive, Naomi and netdimm all failed one after the other!
AndyGeezer
599CR
Crt hate the cold for sure, also in the cold naomi and chihiro fans the gpu ones don't spin, naomi won't boot without the fan spinning, but the chihiro will and then it cooks itself (stupid design).
corn
26 (100%)
231CR
Unfortunately, the cab is indoors and the heating has been on permanently for days - can't blame the cold for this one :-(
I've a nasty feeling this still has something to do with the Forcefeedback. I played a full game no problems with the new drive board installed. Thinking that the feedback felt a little weak, I upped the feedback percentage to 100%. The Chihiro then crashed as soon as the feedback kicked in at the start of the next game. It hasn't been well since :-(
obcd
3,830CR
Feedback is a motor that isn't rotating, so it consumes a lot of current. Maybe something in your power supply didn't like it, so the first thing to check would be the supply voltages.
Bad connectors also can become worse if they had to transport a large amount of current.
