Outrun ic question
Mykill
229CR
I brought some tmm2063p-10 SRAMs but was sent tmm2063p-15 the last number represents max access time in n/s will it be alright to use these instead ,as I read it the last number represents maximum speed it could handle
dj_yt
787CR
Hmm, not sure. I'd socket them and try. From memory, OutRun PCBs have 100ns SRAM for the most part. But perhaps you'll get away with slower SRAMs.
FWIW, I usually avoid purchasing old SRAMs when doing repairs. For starters, they are likely to fail if they are ancient. Secondly, modern equivalents are usually much faster so you won't have to worry about access time issues.
karlcdoe
887CR
as the main man says you could try them, and see if it glitches its way to victory.
FWIW if you get more try and get something close to the same speed rather than super fast alternatives, as some old boards won't run them due to various timing issues/bus noise (insert worldly sounding reason here). No idea how fussy Out Run is though...
karlcdoe2018-02-16 14:39:00
philmurr
48 (100%)
2,378CR
...usually the case. But there are games out there that rely on slow memory, and the faster modern memory can sometimes cause issues.
dj_yt
787CR
Good to know. I've not encountered this myself yet thankfully...
dj_yt2018-02-16 15:50:48
