PAT testing
TheDaddy
14 (93%)
7,230CR
If its just the one around £25.00 ish. Depends how the company charges as its one off, I charge £25.00 minimum.
Dave.
P.S Each test is around £1.60 if your having lots done.
big10p
Coins detected in pocket!
6,092CR
Is that to have all the wiring inspected etc. As well? It's just the one cab. I've completely rewired it in a non-standard way, and would like to have it checked out by a professional. Thanks for the info.
TheDaddy
14 (93%)
7,230CR
PAT testing will only test the cabling & ensure its earthed correctly (Earth Bond Test - Thats if there is any metal on the cabinet thats earthed - else its a slightly different test). They wont go inside and check any of your wiring. Providing its all inside and away from people hands that is. PAT testing will also test the integrity of the cabling to make sure there are no breaks.
A lot of people who PAT test are not electricians and will just fail it as appose to an electrician who will fix it so it will pass.
Dave.
If you want the wires checking inside then you need an electrician to check it over realy. You are too far from me else I would do this for you.
TheDaddy2021-07-01 16:11:32
big10p
6,092CR
Thanks. :) I'm pretty sure I've wired everything properly, but just wanted to be sure it's safe before selling on. For example, I'm using a single 12v wire from the ATX PSU to power everything (just a pandora's box and a few other bits and bobs), except the monitor, which I'm mains switching using a relay. The relay did burn out at one point, but this turned out to be a fake, despite what the seller claimed.
TheDaddy
14 (93%)
7,230CR
Is is just 1 wire from the ATX power supply powering everything ?? If so you can group - multiple wires and then wont mater to much. You dont want to be drawing to much current through one wire realy. Does the wire get hot ??.
If you want to PM me a picture of your concerns I have no problem looking over them.
Lots of Fake relays and switched about. I have seen some extremely dangerous fake parts when I did my 17th edition , they showed us inside an MCB and it was just a pieced of wire the switch never even worked ! Some real scary and very dangerous stuff ! Some people have no concern for other safety at all.
Dave.
big10p
6,092CR
Yes, just a single wire simply because I run it through a cab on/off switch, which then splits off to power the individual 12v components. Pretty sure the wire doesn't get hot, but I'll meter the current draw when I've replaced the relay (bought a genuine OMRON from RS - the difference is build quality is obvious). I may replace the 12v wire to the switch with a bigger gauge, if necessary. So, I can simply tie several of the 12v wires together if I need more current? I wasn't sure as inside the PSU, the 12v wires seem to be attached to different points on the PCB.
Some of the fake stuff out there is shocking. As you say, they don't seem to care about safety, just profit.
Thanks for the offer to look things over. I hope to get back to the cab soon - fit the new relay etc. - and will be in touch when it's done, if that's OK.
Cheers, Dave!
TheDaddy
14 (93%)
7,230CR
Yeh the 12v lines go to different points inside the PSU with different amps, It will probably be fine but I tend to tie them as a precaution. The more the merrier !
Yeh get in touch if you need me mate , No worries there.
We all fall into the "I will buy that its cheap" I do it all the time , We never learn !
Dave.
big10p
6,092CR
So, tying wires with different amps is fine? That's the thing I wasn't sure about.
Nope, never learn.
The genuine relay was about 3x the price of the fake. Thanks mate!
