Looks like standard Gert666 wiring so like on this link below.
https://pinout.xyz/pinout/gertvga_666
If you have put it in backwards as mentioned before, you've probably ended up putting 12v through either the 5v or 3.3v system on the board, as all the joystick/button inputs are pulled to 5v or 3.3v through the 10k resistors around those 3 large ICs just above the jamma connector.
That would probably explain all the burning of the pins on the left hand side of the GPIO connector as those are the 5v and 3.3v in/out from the Pi. (See link above for the pinout)
Have you tested all the inputs to see if they work, as if it was put in backwards it might have damaged the shift registers used for the inputs.
I think 2 of those 100ohm resistors could be for the Horizontal and Vertical Sync signals that then get combined into a single connection on the Jamma connection, Ideally you would need to trace with a multimeter to see where they go to and come from.
Not sure what the 3rd one would be, and the 12k and 6k ones may be linked to the 3 large ICs mentioned above for the controls, the 3rd 100 Ohm one could also be part of this.
I think those 3 big pads below them are there for testing purposes, as they match the 3 connections needed on the GPIO for the controls (Latch, Clock and Data)
They are daisy chained together for the controls and the GPIO is linked to the Clock, Data and Latch pins on the first one (Possibly the left hand one) and the clock and latch will be connected to the other 2 as well, the data pins links to a data input on the chip next to it.
Do you another PI you can test it with, could possibly be that the GPIO on it has been damaged if all the resistors are checking out ok, I suppose you could test the GPIO connections for the video signals to see if you are getting voltage out of them while its running.
Fantazia22019-03-07 19:20:59
