Pleaids IC
jonhughes
1,161CR
Hi everyone,
I'm trouble shooting a Centuri Pleaids PCB and have found a pair of faulty ICs. They are located at IC26 & IC33 on the CPU board. The ICs are labelled M3-7611-5 and the manual is showing these as bipolar prom 7611-5 (Harris). In another working board I have TBP24S10 chips at IC26 & IC23.
I know very little about what these particular chips perform. Are the chips a direct swap or are these things programmed. I know I saw something about bipolar chips on a Galaga repair but are these similar?
Any help greatly appreciated.
shep
378CR
They are 1Kbit (256x4-bit) bipolar PROM chips (tri-state). They need to be programmed with the correct data for Pleiads. You can swap in the TBP24S10's from the other Pleiads board to make sure they are faulty.
jonhughes
1,161CR
Hi, yes I bought two non-working Centuri boards from the States. I've just repaired one and the second is throwing up this issue. Swapped the ICs around and problem disappears. The second board also has a reset issue which I haven't investigated yet - it plays demo perfectly and coins but press start and it resets.
jonhughes
1,161CR
Equites said:
Yeah PROMs, they usually run quite hot too.
Yes these are running hot. The resulting graphics problems vary but the main one is colours. Is anyone able to copy and program the data from the working board I have? The chips are available from littlediode on Ebay.
shep
378CR
I think I have some equivalents (82s129). Let me check. If you can wait a week or so I should be able to help you out. I'm unlikely to get the chance to program these until the weekend. No need to send me the chips, I should be able to get the data from MAME.
4,058CR
Sounds like you're already sorted but if not, I can program the equivalents (82S129) but not the Harris parts. No idea if I have any 82S129's though.
Equites
Chief Sheesher®
35 (100%)
3,332CR
I can burn the Signetics 82s129's but not the equivalents, at least not until I can get my damn Data IO 29B working with Promlink.
jonhughes
1,161CR
shep said:
I checked. I have equivalents (2 different types).
That's fantastic. Just let me know how much I owe you for doing this. I really appreciate the assistance from everyone.
However, that won't be the end of the story. I still have that resetting issue which I have yet to investigate. Please stay around to help me out a little more.
shep
378CR
I'm not fussed about payment for this since you just bought a board from me, however, a small donation to UKVAC would be cool
The resetting problem could be many things but one possibility is a ROM problem. Try reseating the EPROMs. If that doesn't work try swapping the EPROMs from your working board.
shep
378CR
Other things to try:
1) raise / lower voltage in case you have a voltage-sensitive component.
2) check the board for damaged / scratched tracks and test for continuity.
3) swap RAM chips for known workers if socketed.
shep
378CR
I've posted the PROM chips off to you. I used 54s287's (higher spec version of 74s287 and equivalent to Harris 7611 and TBP24S10).
shep
378CR
My trusty old Dataman Omni Pro II. It uses DOS-based software and an ISA card so I have to keep an old Windows 98 PC running so I can use it.
jonhughes
1,161CR
Hi Gary,
the chips arrived today and I installed them and they work just great
Thanks for everything and I've made a donation
Wow, my points have gone up!jonhughes2014-05-20 20:23:00
