Hi all.
So I have an update for this issue. So Gunblade kindly took the chassis back that he originally repaired and fitted a different type fly back, a shot in the dark but it worked fine before the monitor went down and the repair was replacing the fly back.
So re fitted and same issue, re checked everything i checked before and nothing seemed to be wrong.
So I decided to take the guns apart. I rubbed the photodiode with my finger (machine in test) and I got a reading on the test screen. The dot was moving. Tried the second gun and not working, did the same with that and working.
What are the chances of that? So both guns do work but not like they should, the screen only pics up so far until you get to certain points.
I did some reading and it seems that screen burn can efffect it, mine does have screen burn. I also think the photodiodes are shot. They made a PCB that was amplified version which replaced my PCB because of issues but they're £50 each. I would buy them if i knew they would fix the issues, i'm thinking my tube is probably about shot too
Going to buy some photodiode and replace whats on there as surely won't hurt.
Thanks for all the replies and a special thanks to Gunblade for services above and beyond!
John
