Polo 1 problem
bonehead
I'll get pix tonight
50 (100%)
1,729CR
Hi all, I have a polo 1 20" monitor with a wobbly picture down either side.
I had the same problem with 25" polo 2 and Craig at giz10p kindly have me some tips to help solve it.
These are lists below.
Steve, C18 is the feedback for the SMPSU, if this cap is bad you will get no end of issues as the output from the PSU's secondary will be all over the place.
FTW: Id always replace C18 22uf 50v, c25 22uf 50c and C17 220uf 50v on any polo chassis repair regardless. C18 will cause anything from shutdown, wobbles and even blow the HOT depending on how bad it is. C18 is located at the back of the heat sink of the PSU cage, the other two are around the SMPSU IC1.
Id replace those 3 caps, and test the rest of the caps in secondary of the PSU which are all on the back edge of the PSU cage, I wont go through the location numbers as they differ with versions of the Polo chassis.
The question is I can't find the same locations on a polo1 20".
Can someone point me in the right direction with cap locations so I can try the same fix on my polo 1 20".
Could it be the same fix for this monitor?
The picture is nice and bright just not stable down each third of the screen.
I have tried it in another cab and it is still the same.
Cheers,
SteveSteve2014-08-09 10:36:57
bonehead
50 (100%)
1,729CR
Thanks for the picture.
Do you know what caps would correspond to the ones in my previous post for the polo 2 25"?
I could do a complete cap kit but I am unsure if it will cure the fault I have.
Cheers,
Steve
3,578CR
I believe the caps Craig is talking about are C111, C112 and C114. They are all found under the psu cage. The locations Craig has listed appear to be on the neckboard, so they may differ between revisions, although all the chassis i've looked at have the location numbers in the 100's on the main chassis. I always change these as well, as more often than not C114 is at least high on ESR or even completely dead. I even had a Polo 25" chassis a while ago where C111 had been changed but put in backwards, i'm not sure how it was still working but the top had bulged a bit! Needless to say, it was retired and a new one installed! The other caps Craig mentions are the ones in the rear left of the chassis, behind the psu cage.
You need to check the B+ as well, it needs to be 130v I think so put your red probe in the black loop in the yoke plug and black probe in any earth on the chassis (I usually put it in a hole in the lopt heatsink/cage. Adjust the B+ by adjusting the small pot RV101, located under the psu cage. There's a hole (sometimes hidden under a round sticker) in the psu cage for access.
Have you got the psu cage screwed in place or are you running it without (like in the picture above)? I've had interference and slight wobble problems caused by the lack of a psu cage cover before!
(Edit: B+ is 130v on 14"-21", 138v on 25" and above I believe.)
tb20002014-08-09 16:06:08
obcd
3,830CR
You have the large heatsink on the left of your chassis picture. You should at least replace the small capacitor that is located just after that heatsink (not visible on the photo) It's 22uF 50V if I remember well. You might also replace the 2 smaller cap's in front of the heatsink. (One nearby the potmeter and the other on the right of the large capacitor.
If you try to adjust the voltage with the psu cover in place, make sure your trimming screwdriver is isolated. If you connect one of that potmeter pins to the psu cover, you will short your supply.
If that first mentionned capacitor after the heatsink is bad, your B+ voltage will be higher than what it should be.
