Polo 2 problems
pulstar
41 (100%)
459CR
Hi all,
I have a Polo 2 monitor here that has a few problems. When I first received it it would power up fine but after around 5 seconds the screen would go white with diagonal lines and then switch off. I thought the switching off was the OCP circuit kicking in so I adjusted the H Freq pot and now it stays on and doesn't switch off after a few seconds. Where would I start looking for the problem component for this problem?
The next problem is the white screen. Now that I have (temporarily) got it to stay on without switching off the image is normal for a few seconds then displays the below. Any ideas?
obcd
3,830CR
Lower the screen voltage on the back of the high voltage transformer and see if you can make the picture black like that. Check the voltage coming from the supply. It might be 2 high.
If the screen voltage is 2 high, the xray protection circuit might kick in and turn the system off.
I have seen such bahavour on a monitor that had a bad soldering of the Focus & Screen potmeter GND wire. When it disconnected from GND, the focus and screen voltage went up.
The lines are just the beam returning to it's left upper position. They become visible if the screen voltage is turned up 2 high.
If I remember well, the Polo turns on it's supply in 2 steps, the full supply voltage is only switched on after a couple of seconds. Before that, it starts up on a lower voltage. If you have a vertical pcb in your power supply case, it's the one controlling the 2 step turn on.
When you say the picture is normal for a few seconds, do you mean that you can see a normal picture, or just that the tube stays black what you would expect without a video signal connected.
The switchover of the supply voltage could explain the changes you see after a couple of seconds.
There is one 1uF 50V capacitor in the power supply circuit that likes to go bad. It causes unstable higher voltages from the supply.
pulstar
41 (100%)
459CR
Thanks for the response. Yeah, when the screen first comes on it shows a normal picture (I've seen the Rom check for one of my PCBs) for around 5 seconds before flipping to the lines. The lines also shift up and down the screen if this makes any change to the diagnosis.
I'll turn the screen volts down and see if that changes the auto switch off.
Edit:
Right, turned the screen volts down put the H freq pot back and the monitor stays. Now the screen looks green with the retrace lines on them and is now static.
pulstar2014-10-07 12:33:36
obcd
3,830CR
What is the exact type of your polo2?
I have seen it after replacing the LOPT on a polo 2 chassis. The new LOPT had it's screen potmeter turned up to far. It also switched off.
3,584CR
Looks like you're now left with all neckboard related faults most likely. You've probably got a green gun transistor gone down or leaky and maybe a blown resistor if the screen still doesn't show a picture.
pulstar
41 (100%)
459CR
Basically what happens now is, say I have the Neo Geo motherboard connected it will show what looks like the normal boot up screen with the Neo Geo logo then it flicks to the green screen with the lines. I'll take a new photo of what it's doing now shortly.
obcd
3,830CR
If you switch 2 of the drive transistors from place, it should become red or blue instead of green (depending upon which one you exchanged with the green one) In that case it's confirmed to be the drive transistor. Be carefull with your soldering as those pcb tracks often separate from the pcb.
Sometimes, if you measure such transistor when it's cold, it's measuring fine. When you solder it back in, it doesn't work. (hfe measurement)
pulstar
41 (100%)
459CR
T4 removed. Same problem. It's okay for around 2-5 seconds (other than looking a little red because T4 has been removed) and then the same green screen and flyback lines. I've taken a better photo below.
obcd
3,830CR
Can you measure the B+ voltage in the first couple of seconds and afterwards? It's the higher voltage coming out of the supply. It's between 90 and 180V or something like that. (Depends upon the type of polo monitor and it's size.)
Can you exchange T4 with one of the other driver transistors?
If you have a black area in your video signal, is it showing as black, grey, or green?
PaulSwan
ZZZ
1,118CR
I've had a similar issue before on 900 series caused by the lack of ~200V power to the neck board. With no voltage, all the guns are wide open. It's easy to verify with a multi-meter that you have the 200V or so gun drive supply present.
Paul.
gunblade
9,136CR
missing 200v line does cause bright white screen with flyback lines on most chassis(not all) but i would not expect to see the green only
quickest way to prove is to put on another tube,polo 1 is compatible although r36 on the neck card will need to be about 5 ohms
swapping the drive transistors is another quick prove,as mentioned by obcd
pulstar
41 (100%)
459CR
I'll try swapping one of the other drive transistors over to T4 and see what happens. Also where would be the best place to measure B+?
I don't have another tube but I have another good chassis being sent to me but that might not be here until the end of the week or next week. I recorded a quick video to show the flipping of normal colours to green (this is with T4 still removed). Not sure if it will embed nicely so here is the link: http://vid921.photobucket.com/albums/ad51/pulstar1/SAM_2736_zps2d86b88d.mp4
