Problem removing bolts
5,415CR
To me
If you cant get a socket in to undo the hex bolts, which I wouldn't think you could looking at them, how would you get them bolted in anyway
I suspect someone has put bolts through and done up a nut on the back, would look at the back for nuts on them
Hurray Banana
2,761CR
could try drilling an tapping the head if you have the tools, if not cut a slot and use flat blade screwdriver would be safest bet. Ge some replacement torx/hex headed bolts ordered to replace them.
5,415CR
The bolts go through the metal at top of the controller, so if there are nuts they will be just above the controller unit, without access to my machine I don't know how you would get to the back, just looked at my spare control panel to see where they go, the 2 smaller Torx fix the plastic to the wood behind so only the 2 bigger torx and the bodged Hex ones hold panel up at top
Danscu
256CR
robotech said:
You could try getting a cheap socket of the correct size of the bolt and grinding the outside diameter of it down
Or turn it down in a lathe if you know someone with access to one
Some box spanners have a smaller outside diameter compared to the same size sockets so can fit in tight spaces
What size is the bolt head i may be able to get a socket turned down for you and post it
Thanks Shane, very kind of you! Will PM. As some peeps know I have not had much luck with this Afterburner machine. Guess what size the bolts are.... unlucky 13
Equites
Chief Sheesher®
35 (100%)
3,329CR
Is this the cab you were supposed to get now?
What kind of idiot would use bolts on the CP?
Danscu
256CR
Yes it is I believe
No idea why bolts were used though
5,415CR
Only reason you would put bolts like that in is because you couldnt be bothered to get the correct type and or pay for correct type, if they couldnt get security torx allen key wouldnt of been so bad but silver hex bolts is just madnessBods2019-06-19 13:57:37
robotech
823CR
I have pm you dan i may have some sutable replacement bolts too
Any afterburner owners know what size and length the correct bolts should be ?
Danscu
256CR
Hi guys
Me again sorry
Thanks for all your advice but I still have no luck removing this control panel. I have tried using box spanners (size 13) and although they fit, these two bolts are not moving at all.
I have opened the back door and taken a picture of the inside of the control panel. No sure what's going on but it looks to me like they have been welded on?! Would explain why they are stuck fast!
Does anyone know if there is another way to access the non-working lock-on panel so I can sort these lights out
Dan
robotech
823CR
Spray the captive nuts / bolts from the back with some wd 40 and leave it for a few hours and try with the box spanner again
If you have a good engagement with the head of the bolt and the spanner use something longer to turn the box spanner like one of those extra long screwdrivers
The extra levarage / wd 40 should work
5,415CR
They will be welded on nuts from Factory so the bolts can just be screwed into them without having to get a spanner on the back for the nut. The outer 2 are welded same also aren't they
So that's how they should be I would assume, can't get to my cab to look but have space CP to see the back
What I wondered, was if someone had put nuts on back being there is no space to get in with spanner. looks like only the Nut is welded to the metal and not the bolt welded to the nut.
They must of just done them up really tight mate, box spanner you used, you talking one's with Screwdriver type handle? if so and there been done up with Socket set you probably struggle. unless for some odd reason they put threadlock on them, then they could be hard to undo without heating up a bit
5,415CR
You really want to get them out anyway so you can replace with some Security Torx or Allen key so it looks right
Are the bolts the right threads? if the cab was built in Japan and machine came from USA, they don't have Metric, maybe they put wrong ones in and why they won't undo, would of thought the others would be same. did the outer 2 undo easy, can you undo with fingers or were they a bit tight also?
funhouse
362CR
All very good advice. Definitely try using leverage in the hole of the box spanner.
Just thought to add that it sometimes makes sense to very slightly tighten bolts first before undoing them. The tightening can crack nuts that have been locked on.
Also like that heat idea and if they are cross-threaded it will be a problem.
Personally I would try the box spanner with maximum leverage. Keep pushing the spanner down on the head of the bolt and use slow brute-force.
paulie
16 (100%)
103CR
EDIT
a few people have replied whilst I was typing so I now know the nuts are factory welded so disregard some of my comments. I've left them in as it may help someone else trying to release nuts and bolts in other circumstances
Sorry no idea how to access the light.
I've only ever had one instance when my trusty box spanners didn't do me proud.
That was trying to remove a monitor on an Astro. I tried everything and I mean everything so in the end I had to very carefully make several cuts into each of the nuts so not to damage the thread as the bolts are part of the monitor mounting frame then use my box spanner to crack the nuts when sufficiently cut and remove them. I'll be honest it was right old faff!
Kinda thinking out loud now...
Is the nut factory welded? or had someone put the bolt through then welded the nut on?
Heat from a blow torch usually works but the heat transfer could likely bugger the plastic...
Cranking a nut tighter will often allow enough movement to then release it but this would probably crack the plastic, so again no dice...
Have you used plenty of lubrication on the threads? if not do that and use a much longer screwdriver to turn the box spanner
If you have a helper you could try box spanner on one end and something like mole grips on the other and working in sync try to release it.
A very risky method, on the inside you could cut the exposed thread then try drilling out the thread from the inside of the nut, one false move and you could very easily ruin the thread of the nut, once enough material has been removed remove the rest of the bolt with the box spanner.
The only other thing I can think of is to cut or grind the nut off on the inside but if factory welded then that's not an option.
Whatever you come up with, best of luck
paulie2019-06-25 21:32:12
