EDIT
a few people have replied whilst I was typing so I now know the nuts are factory welded so disregard some of my comments. I've left them in as it may help someone else trying to release nuts and bolts in other circumstances
Sorry no idea how to access the light.
I've only ever had one instance when my trusty box spanners didn't do me proud.
That was trying to remove a monitor on an Astro. I tried everything and I mean everything so in the end I had to very carefully make several cuts into each of the nuts so not to damage the thread as the bolts are part of the monitor mounting frame then use my box spanner to crack the nuts when sufficiently cut and remove them. I'll be honest it was right old faff!
Kinda thinking out loud now...
Is the nut factory welded? or had someone put the bolt through then welded the nut on?
Heat from a blow torch usually works but the heat transfer could likely bugger the plastic...
Cranking a nut tighter will often allow enough movement to then release it but this would probably crack the plastic, so again no dice...
Have you used plenty of lubrication on the threads? if not do that and use a much longer screwdriver to turn the box spanner
If you have a helper you could try box spanner on one end and something like mole grips on the other and working in sync try to release it.
A very risky method, on the inside you could cut the exposed thread then try drilling out the thread from the inside of the nut, one false move and you could very easily ruin the thread of the nut, once enough material has been removed remove the rest of the bolt with the box spanner.
The only other thing I can think of is to cut or grind the nut off on the inside but if factory welded then that's not an option.
Whatever you come up with, best of luck
paulie2019-06-25 21:32:12
