by the way just to mention the test I did on the diode, I used my digital multimeter set on 'diode test', and using the probes as normal, I got a reading of .086, but then when I reversed the probes, I got the same reading of .086, which I assume is a bit weird
ps. afterwards I also tested some other various types of diodes with my multimeter (to make sure it wasn't my multimeter at fault), and got normal readings with the probes used in one direction, and then a reading of 'infinity' if the probes are reversed, so it looks like my multimeter is ok
