Question about Diodes
joe34
448CR
hey all, can anyone help with this please
I have a diode, see picture below..
I tested it and think it is faulty. how do I determine which replacement diode I need to find (eg. type/value/etc) .. im clueless with diodes as you are probably noticing..
RaveN
1,325CR
Are you able to take a pic of where it came from on the pcb?
If you're lucky we might be able to work out what it's doing, if it's a zener diode or just standard power section blocking then we can guess a substitute. If it's part of the display/video section then it may be a bit tricky.
joe34
448CR
RaveN said:
Are you able to take a pic of where it came from on the pcb? If you're lucky we might be able to work out what it's doing
hell yea
I will take some pics and provide more information later on then, many thanks
joe34
448CR
by the way just to mention the test I did on the diode, I used my digital multimeter set on 'diode test', and using the probes as normal, I got a reading of .086, but then when I reversed the probes, I got the same reading of .086, which I assume is a bit weird
ps. afterwards I also tested some other various types of diodes with my multimeter (to make sure it wasn't my multimeter at fault), and got normal readings with the probes used in one direction, and then a reading of 'infinity' if the probes are reversed, so it looks like my multimeter is ok
joe34
448CR
philmurr said:
Are you sure it's a diode ?
Are there any markings at all on it.  Or any markings on the PCB from where it's been removed?
see pic above, unfortunately I have no idea what it is
I will get some pics up hopefully tomorrow of the pcb
joe342015-07-03 21:58:49
