R Type 2 stuck inputs
virtvic
The Cabaret King
21 (96%)
2,012CR
This is following on from my question about fixing resistor arrays - or in my case, replacing one to try and fix my r type 2 conversion form the ship going down all the tim.
When I first noticed the problem, you could hold up to stop it moving, but it would inevitably go all the way down. You could stil go back and forward and fire.
I replaced the resistor array and now no movements work and it still goes all the way down. You can fire though.
Any ideas where I should check next?
5,332CR
I've not looked at Rtype schematics, but inputs usually go to a bus IC (e.g 74LS257), so I'd be checking at the inputs to this to see they toggled when the switches are pressed (if not, there's a track or resistor issue before the IC). If all that's ok, then checking the device itself is probably an oscilloscope job as the outputs are gated (lots of other devices share the data bus). Piggy-backing a new IC is a cheap trick that often works. Check the schematics anyway to see what's next, and double check the resistor to be sure you've not knacked it somehow (not in backwards is it?)John Bennett2018-01-24 23:17:39
virtvic
The Cabaret King
21 (96%)
2,012CR
The resistor array is in the correct way and all the pins read what they should now (4.7k ohm) - 2 of the pins were reading 1.something K on the old array)
I'll check out the LS257 tomorrow - thanks!
5,332CR
I don't know if R-type 2 is the same, but R-type has LS244's. As said, you'd need a scope to know they were working as the output only follows the inputs when they're enabled.
There's filter caps to ground in there too.
edit: - actually one trick is (with the board unpowered ) to put the multimeter on the diode setting, then put the red probe on 0V. If you put the black probe on the pins to the 74ls244, then the inputs should read similar millivolts (if one input is hugely different, then it may be suspect). It's a very basic way of checking if the chip internals are blown-up (better than a resistance check).John Bennett2018-01-25 08:05:03
virtvic
The Cabaret King
21 (96%)
2,012CR
I've been trying various things - found that the via on pin 4 of the resistor array was broken, so bridged that.
With my logic probe, pin 4 goes low when DOWN is pressed on the stick, but pin 5 stays high.
On my working major title board pin 4 & 5 go low when DOWN is pressed.
Problem with pin 5 (which goes to the LS244?
5,332CR
You sure that's right? Not sure why 2 I/O lines would change when you're only closing the down microswitch.
Are all pins of the array at 5V with the joystick and buttons left alone?
virtvic
The Cabaret King
21 (96%)
2,012CR
Not near the pcb at the moment. Doesn't pin 5 of the resistor array go to the LS244?
(The working MT pcb) pins 4 and 5 go low when down is pressed. I'm presuming this is correct?
The pcb I am working on, pin4 goes low but pin 5 stays high.
5,332CR
Ah, sorry, I wasn't looking properly at the resistor array.
It's 4 channels, each with a series resistor and a pull-up resistor (the series resistor forms an LC filter with the capacitor).
So, yes, as you say, 4 and 5 should go low when pressed (both sides of the series resistor).
Sounds like the 74LS is shorted hign. Can you do the test with the diode setting of the multimeter, see if the 74LS inputs all look the same? You can also put the black probe on 5V and the red probe on each of the 4 inputs - you'll see a different result to the other test, but all 4 pins should read the same-ish.
Out of curiosity, what part number was the replacement resistor array?
5,332CR
Yeah, if Major Title/Rtype2 has the same arrangement as R-type then you've probably got the wrong resistors.
For a test, you could short out pairs:
2&3
4&5
6&7
7&8
You won't get the benefit of the RC filter and the pull-up resistance will halve (to no obvious effect), but you should be able to get it to play.
virtvic
The Cabaret King
21 (96%)
2,012CR
Just tried that - still doesn't work. In fact none of the inputs work, as before I replaced this part left and right were still working and if you held up, it would stop going down.
I think I stated that already.
Do you know where I could get the correct resistor pack - a number or a link to get one please?
5,332CR
Hmm, odd that that doesn't work - if the diagram applies, then you just need to get a series connection from the I/O pin to the 7$LS and also a pull-up to 5V.
Anyway, if the other original resistor networks are still present, probably best to measure them.
If you measure the resistance between
pins 2&3,
pins 2 & 1
pins 3 & 2
Should read the same for the other pairs too.
That should show what's going on inside.
Fantazia2
2,246CR
It looks like they are custom Resistor Arrays and not the ones you found.
Have found some info here: Link
Havent read it all yet, but it mentions someone doing the same as you and replacing the custom resistor arrays with standard 4.7k ones.
virtvic
The Cabaret King
21 (96%)
2,012CR
On an existing array - 1&2=4.64k 2&3=0.22k 3&4=9.55k
On new array - 1&2=4.7k 2&3=9.41k 3&4=9.4k
There is definitely a pattern difference here.
The code on the original part is 8m462j22ij Cm02
Fantazia2
2,246CR
I think it might be something like this.
Between 2 and 3 there are 2 resistors in series with the middle joined to the common pin 1.
So on the old one that works try measuring resistance between
2 and 3
2 and 1
3 and 1
and compare that to between
4 and 5
4 and 1
5 and 1
and then the others if that makes sense.
EDIT: Actually looking at your first set of measurements I think I have that wrong, will see if I can work it out.
The numbers after the 8m part refer to the 2 resistor values
462 means 4 6 then 2 x Zero so 4600Ohm or 4.6k
221 means 2 2 then 1 x Zero so 220Ohm
Fantazia22018-01-25 22:48:05
Fantazia2
2,246CR
I think I've got it.
It looks like it may possibly be setup so that each of the lines 2 to 9 and linked to the common Line1 with a 4.6k Resistor (4.7k from the part number in your schematic above), this is the same as the one you have installed.
But then in the custom one there are 3 extra resistors that are 220ohm that bridge the 4 pairs, so between 2 and 3, 4 and 5, 6 and 7 and then 8 and 9.
If you see my link above the guy leaves the standard resistor array like the one youve got in place and then adds some SMT resistors to the solder side jumpering between the pairs.
That part of what they were doing didnt make sense to me at first but from your measurements above it does now.
5,332CR
Yes, it's probably as in the link - 4.7k pull up and 220 in series. The 220 will be in each pair, rather than between pairs.
But, I thought you said it didn't work when you shorted the pairs (which is effectively adding the series resistance, just with 0 ohms rather than 220)?
I probably should've sketched it out.John Bennett2018-01-25 23:01:39
Fantazia2
2,246CR
It could be that it needs the resistor in there instead of shorting to get the correct signal/voltage level for the IC it connects to
