Now the resistor should be sorted, what is the down input at the 74LS244 doing? Is it toggling, or stuck?
If you can pull it to 5V using a resistor (4.7k ideally, or something of a few K), then there's a broken track between the resistor and the 74LS244. If you can't pull it and it's stuck low, then it's the IC (and you might actually not be able to sort it by piggy-backing as it'll drag the new IC down too, although still worth trying too).
Edit: - there is also the filter capacitors in the circuit too - doubt they'll go short circuit, but something else not to forget about too.John Bennett2018-01-26 21:48:58
